Old 11-06-2005, 04:43 PM   #1
fossilrunner
fossilrunner's Avatar
help me decide on tires
i am trying to decide if I should run a 285/70-15 or a 275/60-15 on the back. On the front I want to run something that is 26" tall.A 235/60-15 is to wide.I was thinking more like a 205 or 215.below is what it looks like right now with the 235/75-15 on all 4's
71 chevy lwb w/ 350,750 holley 4150,edelbrock performer rpm,full 2 1/2 exhaust exit out side,6-8 drop,rally wheels.-SOLD
74 Chevy nova-355 with a little nitrous
78 GMC Jimmy 4x4-Factory 400 and all stock.
fossilrunner is offline   Reply With Quote
Old 11-06-2005, 06:08 PM   #2
69 longhorn
Re: help me decide on tires
I am running a 255/70/15 on the rear(29" tall), & have 225/75/15's up front(28.25 " tall)......but plan to go with a 225/70/15 up front to get to about 27.5 on the fronts. I run rallys on my longhorn also (15x8's rear & 15x6.5's up front). You can figure the 275/60/15's to be right at 28" tall......the 285/70/15's im not sure on the height, but think they may be really tall compaired to what you are planning to run up front. best of luck, L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 11-06-2005, 06:31 PM   #3
subtle71
Granddad's Ol' Truck
subtle71's Avatar
Here is what mine looks like with 275/60/15 and a 3/5 drop. It looks like your drop is similar.
Dean
1971 Chevrolet Custom 10 short step-side
2005 GMC Sierra SLT 2500HD crew cab 2wd
[I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side
subtle71 is offline   Reply With Quote
Old 11-06-2005, 07:11 PM   #4
truckdude239
truckdude239's Avatar
umm i just got 255/70r15 all the way around and my handles like an dream
truckdude239 is offline   Reply With Quote
Old 11-06-2005, 09:29 PM   #5
uncle
A 285/70 is 30" tall give or take a little depending on your wheel width. I have pics of 2 different trucks with different wheel widths. If you want pics, just send me your email address. I ran 235/70 on the front of both.
uncle is offline   Reply With Quote
Old 11-06-2005, 11:24 PM   #6
fossilrunner
my drop is about 6-8
Old 11-07-2005, 08:54 PM   #7
1978steven
1978steven's Avatar
Do the 235's you're running now rub in the front? Are your wheels 15X8's all the way around? If you have 8's all the way around you might see if you can get some 7 inch ralleys for the front, and see if your front tires work better. The 7 inch ralleys should have a better offset for the front of your truck. I've seen the 7 inch ralleys here on the board pretty cheap. As far as the back tires I run 275 60 R15 on my 15X8's and they look great, you could try the 285 70 R15's, but your truck will be really rake with the super tall back and short front.
Good luck, Steven
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
Old 11-07-2005, 09:12 PM   #8
uncle
One of the trucks I had was a 6" spring with a 3/4"block and 285/70 15 on a 10" corvette rally style wheel with no problems. The 6/8 drop is gonna be more of a tire question for the bagged truck guys.
Old 11-08-2005, 07:03 PM   #9
fossilrunner
I have decided for the fronts I am going with a 205/65-15 on a 7 inch rally and on the rear, either a 315/60-15 m/t drag radial or a 29X12.5-15 m/t sportsman
Old 11-08-2005, 07:45 PM   #10
68Stepbed
68Stepbed's Avatar
I wish someone made a 275/65/15 or a 285/60 or 65/15. You could get some height withe width without going too tall.
I wouldn't run the 285/70's. IMO they look like you tried to stuff a 4x4 tire on a 4x2 truck.
Just my .02
Matt
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-08-2005, 09:19 PM   #11
smbrouss70
smbrouss70's Avatar
if you're running 2.5" drop spindles, you might want a taller tire than 26" up front. I'm running 26" tires with drop spindles and my control arms drag way too much. I'm thinking I should go with a 27" up front. Not to mention that personally I believe the 26" tire is too small to fill that fenderwell properly, my $.02
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 11-08-2005, 09:25 PM   #12
smbrouss70
smbrouss70's Avatar
Just to let you see... 4.5/6 drop with 26" tires up front & 29" tires out back...
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
