Old 11-06-2005, 04:49 PM   #1
67gmcss
air cfm??
It's been a while. Like the new look of the site. Here's the question: I am getting an electric fan for the 67. I was wondering what the stock airflow cfm is so that I know I am getting enough that I don't kill the v8. Any help is greatly appreciated.
67gmcss is offline   Reply With Quote
Old 11-06-2005, 07:48 PM   #2
67gmcss
Re: air cfm??
Also, does anyone have pix or easy way of removing heater control unit? thanks again.....
Old 11-06-2005, 08:06 PM   #3
69 longhorn
Re: air cfm??
I couldnt say what the airflow on the stock fan setup was. I run two 14" flex a lites, that are said to pull 1350 cfm ea, on a homemade shroud,4 row core, & painless wiring controls. The setup keeps my 383 cool in the 90 plus temps here in Illinois. L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 11-06-2005, 08:22 PM   #4
67gmcss
Re: air cfm??
thanks longhorn. I was looking at one on e-bay that is a 16" that says it's 2750 cfm.....no shroud. Wonder if that will make a big difference over running a shroud?
Old 11-07-2005, 10:01 AM   #5
69 longhorn
Re: air cfm??
I dont think I would mount the fan to the radiator core , like the manufacturers suggest.....IMO, it will beat the he!! out of the core, & wear holes in the tubes after some time. I think a couple guys have mounted a 16" puller fan to the stock shroud(after trimming), & it worked fine for a mild sb daily driver. space may be a little tight tween the waterpump & the fan tho..... a sb in I 6 position will have more room . best of luck, L
