Happy to be here
![]() Join Date: Mar 2000
What did you get done?
I worked this weekend so the only thing truck realted I did was wash a couple of drivers. Beyond that I researched travel arrangments for a trip to Atlanta in March.
Today I worked in my yard doing a bit of clean up, killing ants and planted some fall color. What did you get done?
Web Wheeler
Re: What did you get done?
I worked Saturday... can't complain too much - it was at double-time
![]() I had to fix my Burb before I could drive home though ![]() ![]() So on my lone day off (today) I went for a walk to the park with my wife & kids. ![]()
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
You get what you pay for
![]() Join Date: Dec 1999
Installed my Lokar throttle and kickdown cables. Only thing truck related. I did have to cut down two Dogwood trees. There is some kind of disease going round that is slowly killing them. I had two that finally gave up the ship.
Mike 1985 Chevy C-10 |
I changed the oil and washed my new daily:
![]() ![]() I picked it up last friday. It has 25k miles on it, 03 premium package, 5 spd. Got it for 15k. It also has full SLP exhaust (long tube headers, cats, x-pipe, and loud mouth), K&N FIPK, Dyno tuned with a Dialbo Sport II tuner. I know its a ford, but man its a blast to drive. Other than that I took the '78 up to lowes to get a few 2x4's to fix my futon with. It finally broke the other day. Thats it beside some cleaning of the house.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
I actually did something to my 84 today! My buddy dropped off my step bed that has been sitting in his garage & my son & I sat it on the truck. I took a bunch of pics & sinse I had his trailor here we went & picked up the short fleet bed the body shop guy gave me. Out came the camera again. Im having a hard time deciding which box to use but Im leaning toward the fleet side. Any comments??? corn
Professional Grade
I collected all of the clutch parts I need less the cab hump for my standard tranny swap. I'm gonna tackle that this week
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
![]() Join Date: Jul 2001
I changed the oil and filter on the '91 Burb, changed out the thermostat also. Winter coming on and the better half likes the heat to work when it's 15 degrees and snowing.
![]() cornfed: Just my two cents but I like the fleetside bed also. Think it follows the truck body lines better. Again, my two cents.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks Last edited by Ironhorse; 11-06-2005 at 08:33 PM. |
North Coast, baby!
Does calling the plumber to roto rooter the drain count? Late entry from last weekend: Finally got the new roof on the house, added more vents and painted the new fascia board. Got it on just in time to weather the storm last night. 60mph winds in my neck of the woods. Nothing truck related.
Brad 79 Scottsdale C20 ![]() 350/350 3.73's Still running full CA smog gear! ![]() |
Trucker.
Friday night I rolled to Gainesville with Kenduhl to drop off Hamer Toes'(LOHRTBT) new truck and have dinner at Chili's(damn the service was slow).
Sunday I put mobil 1 5w30 in the Tahoe with a PF1218 Delco filter. I greased the front end on Jess' truck with Mobil 1 synthetic grease. |
Robert Olson Transport
![]() Join Date: Oct 2002
this is the first time in a long time i can honestly say i did something 73-87 related. I went and looked at a 1987 c 30 today as a possible work truck/get around vehicle. It has the utility body on it as opposed to a regular bed and it sucks gas like a pig but for its age it didnt look bad and it has the setup for air conditioning so i may consider it. The girl friend is all for it and she even liked driving it but im not sure i want to buy such a truck..
I slept in. I know that sounds lazy, but after 4 straight weeks of 70+ hrs, I needed it.
I actually got out to the garage too! Saturday, I pulled the balancer off the 350 that came out of N2TRUX's 77 & then swapped the timing set out for a Cloyes Dbl Roller set-up. Installed a new Mellings oil pump. Cleaned up the front timing cover (which looked good from the outside but was a mess everywhere else). I did the running around BS searching for the right bolts to get the V8 in place of the inline 6. Today I had to run up to work & use the larger bench-vise to fix my balancer installer/remover that got messed up on Saturday (1 use & the threads were boogered up already ![]() ![]() Technically, this motor swap is for my 68 & this is the 73-up area.... but the engine was in a show worthy 77 so I figure you guys will indulge me. I'll get some pics of the install & the motor sitting on the stand & stuff. I'm going to do a product assessment on the 'Performance-Online' tubular engine frame mounts + trans crossmember & will share my thoughts.
Well it is also my weekend to work so I have done nothing truck related. I actully left it home all weekend so my insurance adjusted could finally finish her paperwork and take a few more photos. Still haven't heard from the other guys insurance company? I am going to call them tomorrow. I actually rode the bike into work this weekend so the truck would be available. Man I love Arizona, motorcycling in November! That was fun, I have been ignoring it for a while.
Cornfed- I am also a fan if fleets but that step looks really good too! I love that stance, can't wait to drop mine some more! Hot Hot Hot!!! Good luck making that decision it is going to be a toughy!!!
1959 GMC project |
#13 |
Village Idiot....
Well as always I didn't work on anything truck related or anything that belongs to me. I did however finished my frig that I sold to a customer that had to have it after I restored it but he wanted a Rat Rink painted on it among other things so it's finally done and I can now check another project off my list. If you can zoom the "BC" can in his hand read the writing at the bottem of the can, just our little friendly slam to Boyd!
#14 |
Village Idiot....
Well I guess I should have loaded a better picture of the can so ya'll could see it better......
#15 |
The Peacemaker
nothing truck related....I was in spokane visiting relatives for the weekend.
1978 Chevy 2wd Stepside aka "Audrey" Cordova brown with mandarin guts 79k original miles & being restored 1979 Chevy 2wd Short Wide aka "Emma-Jayne" Cordova brown with mandarin guts 2019 Chevy Tahoe LT Previous rides: -2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB. |
#16 |
what did i get done?...i worked,
1987 350 TBI lowered 5/7 |
#17 | |
![]() Quote:
n2trux.....wow...what a house ya gots there ![]() ![]()
#18 |
I made some extra work for myself...
~Steve~
Friesen High Performance Auto and Graphics Toy: 87 Shortwide, 406 smallblock with a little boost My 87 buildup Daily Driver: 99 Sierra SLE 4X4. Black on Black and harder than hell to keep clean. ![]() |
#19 |
Still Green but learning
installed the headlight buzzer, cool.. put the house on the market. O yea contracted a stomach bug and spent 2 days trying to get it out of me (ew)
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
#20 |
i have pretty much finished the frame i also found a trans, croosmember that i wanted the one that has the two humps in it
square body trucks an addiction or an investment either way they consume all my extra time and money |
#21 |
![]() brackets, pulleys, belts, p.s., p.b. did I mention seacching around h e l l 's half acre to find specialty fasteners?
Chuck 1972 C-20 Longhorn 402 BB .030" over (409?), curved HEI, RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit 1999 K1500 Suburban (old style) 5.7L Vortec 4L60E "No matter where you go, ........ there you are" |
#22 |
BeWarE tHe eViL CrAnkTOe!
Well after I met up with Izzy and Kendall..Drove my new bucket back home and got to work on it. Washed and clayed it that night when I got home.
Sat and Sunday, I sprayed in bedliner, Painted the lower dash black to match the rest of the black interior, painted the gauge cluster and cleaned up the gauges from dustiness, replaced the light in the a/c cluster, replaced teh light in the domelight, undercoated the wheel wells, Did some experimental fixing on the door panels that were really messed up...might just end up replacing them. ![]() Found that the radiator has a hole in it and is foaming badly when I stop after driving. So I need to have that fixed. I think this week I am gonna pull that out and replace or repair it, get new plugs and wires and then really detail out the engine bay. whew!! hehe
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
#23 |
www.73-87chevytrucks.com
I started repinning the 7730 (TPI) harness to work with the 7749 (SY/TY turbo) ECM. I didn't post this but about 3 weeks ago I got the upper TPI intake sandblasted.
Here is a crappy pic of the TPI harness work starting...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#24 | |
#25 |
Crazy
Cornfed Go with the step!!!!!!
77 SB Stepside in a bunch of pieces scattered around the garage. |
