11-06-2005, 08:23 PM | #1 |
Keep On Truckin'
8MM straight boot plug wires
Been trying unsuccessfully to find a set of 8MM plug wires with straight spark plug boots for a 350. Does anyone know what applications meet the need
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
11-06-2005, 08:27 PM | #2 |
Re: 8MM straight boot plug wires
Are you looking for stock factory style or aftermarket? Taylor or MSD has the type your looking for if you want aftermarket. I have a set of straight boots on my 74 Corvette that are factory style that go under the manifolds.
11-06-2005, 08:31 PM | #3 |
Ive got a set of yellow accel 180 degree(straight boot) wires that I bought installed & took right back off for a set of 90 degree wires. PM me if you are interested in them...
11-06-2005, 08:38 PM | #4 |
Taylor for me too same as Rat Rod. Corn fed is on to a good thing .
a |
11-10-2005, 01:54 PM | #5 |
What kind of distributor are you running? Is it a stock HEI distributor?
The stock application that has staight spark plug boots is for a big block engine that has the wires going over the valve covers. It works well on small blocks. It is what I use with my HEI distributor. I can post the exact application tonight. |
11-10-2005, 03:37 PM | #6 | |
Keep On Truckin'
11-10-2005, 09:23 PM | #7 |
My son, my joy.
Doesn't Accel still make those universal cut-to-fit sets? You can buy either straight or 90's. I've had em on my truck for years.
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400. Founding member of the No Money To Spend On My Truck Club. When your at Home Depot, you WISH you had gotten an 8 foot bed! |
11-10-2005, 10:58 PM | #8 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I run some for a 70's Corvette.SBC 350,HEI,Ram horns.
Straight boot,they fit well.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 11-10-2005 at 10:59 PM. |
11-12-2005, 03:35 PM | #9 |
For a straight-boot 8mm plug wire set with an HEI distributor, the application is a 1976 one-half ton truck with a 7.4 litre Big-Block engine. The NAPA part number for this is 700242. Even though it is for a Big-Block engine, the wire lengths work well on a small block engine. That is what I use, and I run the plug wires over the valve covers and my Ram Horn manifolds. LOL
