Old 07-09-2002, 10:10 AM   #1
RodC
RodC's Avatar
Brake fluid on shoes
Brake cylender went south, leaking fluid on rear shoes. Can they be cleand/saved or should I replace them?
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 07-09-2002, 10:26 AM   #2
boilrman
70 Chevy 3/4t
from my experience and my opinion.
If the wheel cylinder has not been leaking for a long time, you can probably clean the shoes with some brake parts cleaner and be OK.
If the wheel cylinder has been leaking for quite a while and you just now found it, replace them as they can become sticky.
If you are unsure of how long it has been leaking, better to replace them.
Find a job you love and you'll never have to work a day in your life.
1998 Yamaha V-Star 650
1970 Chevy 3/4t, I6 (rebuilt), 4 speed
Kokomo,IN
boilrman is offline   Reply With Quote
Old 07-09-2002, 10:28 AM   #3
1ToBjimmyk5
I would replace them and clean the drum with brake cleaner
MY $.02
1971 Chevy Blazer(looks like Jimmy),1988 Ford E350 Van,2001 Nissan Sentra(Wife), 1993 Nissan Sentra (to/from work),1985 Dixie (boat) with a big Johnson,And I want my 1970 Buick Conv. back!!!!
Centreville,VA
1ToBjimmyk5 is offline   Reply With Quote
Old 07-09-2002, 10:29 AM   #4
Sierra
If it was my truck, I wouldn't hesitate to replace the shoes. Better to know what you have, rather than take a risk with something as important as brakes.
Sierra is offline   Reply With Quote
Old 07-09-2002, 10:44 AM   #5
junkyardjohn
junkyardjohn's Avatar
Talking
ONE TIME YEARS AGO, WHEN I WAS WORKING ON A TRUCK I WAS RESTORING, I HAD IT IN MY DRIVEWAY, GUTTING THE INTERIOR. WELL I STRIPPED EVERYTHING OUT OF IT, NIGHT TIME WAS COMING ON. & I FIRED IT UP TO BACK IT INTO MY GARAGE. I HAD SHORTS ON, & AS I BACKED IT IN, I FELT MY RIGHT FOOT GETTING WET. I HAD REMOVED THE INSTUMENT PANEL, & FORGOT ABOUT THE OIL PRESSURE LINE, & PUMPED ABOUT 3/4 OF A QUART OF 10 W 30 IN MY RIGHT SOCK, RUINING A GOOD PAIR OR REEBOCKS.
OH -- YOU MEAN BRAKE SHOES !!! WELL IT REALLY DEPENDS ON HOW BAD THEY WERE SOAKED. I,VE SOAKED EM DOWN GOOD WITH "BRAKE CLEAN" (IF THEY WEREN'T TOO BAD) & THEN PUT THEM ON THE BELT SANDER. BUT IF THEY APPEAR TO BE WATERLOGGED (OR IN THIS CASE "BRAKE FLUID LOGGED") I THINK I'D GO AHEAD & REPLACE THEM
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-09-2002, 11:20 AM   #6
68 Suburban
68 Suburban's Avatar
If they were regular brake shoes I would just replace them because they are cheap enough. But if they were my kevlar shoes I would try everything to clean them up because they ain't cheap
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 07-09-2002, 12:49 PM   #7
COBALT
COBALT's Avatar
The brake fluid goes in the master cylinder, not in your Nikes.
lol -- replace them.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
