its all about the +6 inches
What's the differance...
I got a PM asking this, and I (think) I have it down...but was unable to put it into words....
What is the differance between a bog and a stumble? |
![]() Join Date: Jul 2004
Re: What's the differance...
I think a bog is a more severe form of stumble ??? Like maybe when it bogs, it doesn't hit on any cylinders for a while, a stumble is less severe, like maybe it hits on a few holes, for a shorter time, then recovers ???
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Questionable
i always thought a bog is when it was firing on all cylinders but the RPM's are low so it's running really "chunky" whereas a stumble would constitute misfiring or backfiring.
shoot me if i'm wrong.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#4 | |
![]() When I go 4-wheelin' I bog the engine down when climbing hills sometimes (too steep!). When my buddies get water in their distributors from muddin' their engines stumble.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
well ok, let me clerify.... bogging I am refering to is more like an off the line bog, when you are running too rich.... a stumble is supposed to be when you're too lean.
How does one tell a bog from a stumble? |
'Burban Legend
![]() Join Date: Apr 2005
Andy,
This is how I see what you are asking. A bog is when the engine is getting more fuel than the RPMs can compensate for. (which is basically what towrig is saying in his particular case. (too high of a gear for the RPMs) A stumble is more of a lean condition problem, because you stomp the gas, and it takes a second for the fuel delivery system to catch up to the needs of the engine at a particular RPM. If I was going to describe it in a "sound",(don't laugh) it would be the difference between a "bowah"(bog) and a "phitwah"(stumble) You said you wouldn't laugh.... Just trying to put it in the simplest terms, since you asked. Take care, Mike
'67 Chevy Iron City Beer Truck (9ft step) '67 Chevy Panel Truck 467 '68 Short Fleet 305v6 '68 McLaren Ramp Truck '68/'68/'70/'71 Burbs 292/366/402/454 '69 C-30 dump '71 C-50 dump and church bus '71 4x4 454 '72 Blazer (w/pop-up camper) $15 x-hooks '66 Chevy II 194/Weber '68 El Camino" 305v6 '69 Skylark 455 Buick '70 Chevelle 427 '71 Cutlass W-31 '71 GTO 400 2x2 "The 51" Chopped '51 Chevy (409) my first car OK Toad, we'll take 'em all... John Milner |
Here's my take...
Stumble=lasts only a second, comes out of it, without getting out of the throttle. Bog=Continues to pull down until you get out of the throttle. Does that make sense to anyone besides me?
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
Where's my beer?
I think sdkid nailed it dude! but what do I know?
Professional Grade
Bogging to me is working extremely hard, but not getting anywhere, while a stumble is going like crazy, but misfiring for a second or something.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
