Old 11-08-2005, 02:31 AM   #1
HeavyD
HeavyD's Avatar
How much play should there be in shifter arm??
I was looking at the steering columns I have and noticed the shifter arms on both have some play. When I wiggle the arm up and down, the end knob moves a total of about an inch or so (this is a guesstimate). Both columns have roughly the same amount of play. Is this normal? If not, how can this be repaired?
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is online now   Reply With Quote
Old 11-08-2005, 08:07 AM   #2
vtblazer
vtblazer's Avatar
Re: How much play should there be in shifter arm??
Check all the linkage starting from the steering column down for wear and/or missing bushings.
Check the metal parts from the frame to the tranny also, they wear considerably.
I just did this yesterday and ended up needing to weld a couple of the parts in order to 'build' them back up to what they should be.
You'd be amazed at how an 1/8" of worn off metal down on the tranny linkage will affect the shift lever feel/wiggle.
vtblazer is offline   Reply With Quote
