Old 07-09-2002, 03:52 PM   #1
WORNBRAKES
Transmission coolers?
Looking at putting in a cooler but have to ask a few questions first. Wear is a good place to mount them? What is a good size to go with? When you remove the lines from the radiator, what is the best way to cap off the radiator hard lines? Any sugestions on a good quality would be great also. I am running a 327/350 with a 4:10 rear. I appreciate any imput.
Thanks,
Mario
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 07-09-2002, 04:04 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Hey Mario,
I'm thinking of the same thing. I've talked to a few people. B&M makes these but I think you can get a nice one at your local parts place. Most people mount these to the radiator but I have heard of mounting to the frame also. I think at least a 19,000 GVWR will be fine. Your radiator lines will run thru the new unit. It's a fairly easy job. Good luck!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-09-2002, 04:09 PM   #3
1ToBjimmyk5
I put mine infront of the "a/c radiator" (can't think of the name) and just cut the line going into the "real" radiator. The one I have is rated at 15,000 lbs.
I don't think it needs to be that HD but that's me "OVERKILL EVERYTHING"
1971 Chevy Blazer(looks like Jimmy),1988 Ford E350 Van,2001 Nissan Sentra(Wife), 1993 Nissan Sentra (to/from work),1985 Dixie (boat) with a big Johnson,And I want my 1970 Buick Conv. back!!!!
Centreville,VA
1ToBjimmyk5 is offline   Reply With Quote
Old 07-09-2002, 04:19 PM   #4
6869704X4
Lots of good stuff here, oops had the wrong page.
http://www.permacool.com/Catalog/Contents.html
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 07-09-2002, 04:34 PM   #5
Super Chevy
Super Chevy's Avatar
Im running a 5 pass 3/8 line alluminum cooler infront of the radiater,i have a 12" fan sucking though it also, i plan on running hardline though my radiater then though the cooler then back to the trans, i dont think you can be too cool with trans fluid
Super Chevy is offline   Reply With Quote
Old 07-09-2002, 07:51 PM   #6
68 with 350 TPI
68 with 350 TPI's Avatar
I went down to the local parts store and got the bigest one I could find.
The lines are easy to cut with a small tubing cutter and then use some hose to attach the new trans cooler to the trans lines.
Then I got the cooling fan off of a geo metro and put it on top of it. I wired in a thermostat switch to turn it on and off so I dont have to mess with a switch
I mounted mine in front of the AC condensor with the little fan on top pushing toward the engine.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-10-2002, 01:13 AM   #7
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
After reading this, I just went and picked one up too. It's a B&M Supercooler, 19,000 GVW I believe. I had to cut one of my stock cooler lines, but it went in without too much trouble. I mounted it to the radiator support instead of the radiator itself.
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 07-10-2002, 01:50 AM   #8
Hooter
My other Love
Hooter's Avatar
love the "wish you were here" pic PINK FLOYD RULES!
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 07-10-2002, 07:31 AM   #9
RipMeyer
RipMeyer's Avatar
I just took mine off along with the oil cooler. The A/C condensor the oil cooler and the tranny cooler Restrict to much air flow into the radiator IMO.
RipMeyer is offline   Reply With Quote
Old 07-10-2002, 10:12 AM   #10
WORNBRAKES
Well I ordered the same cooler as Patric Sullivan yesterday. The B&M supercooler 19,000 and it will be ready for pick up tonight.
I replaced the traney a year and a half ago and have put about 3000 miles on it since. I figured with the long drive ahead of me, I would rather be safe than sorry. The wife would rather fix it when it is broke but you know, I am all about prevenative maintenance.
Thanks guys,
Mario
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 07-10-2002, 10:16 AM   #11
Low69CST
Check out these pics of my Perma-cooler. Made brackets out of aluminum bar.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-10-2002, 10:17 AM   #12
Low69CST
Forgot to mention, these are very old pics! My frame still in Varaprime and the other motor in it.
