11-09-2005, 10:21 AM | #1 |
Junior Member
steering box question
does anybody know if 73 and up steering boxes are the same as our 72 or were i can buy parts. thanks
11-09-2005, 11:34 AM | #2 |
Re: steering box question
they should fit but don't hold me to it lol
11-09-2005, 12:25 PM | #3 |
Gone Fishing
If i remember correctly they will work up to 78. Then they changed the pitman arm design
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
11-09-2005, 12:38 PM | #4 |
I heard up to 76 they are the same.
11-09-2005, 04:56 PM | #5 |
its all about the +6 inches
well, to be 100% acurate, they are not the same. The later ones are variable rate while the older ones are fixed rate.
However, the replacements ARE the same up to 76 or so, after that they went to metric fittings and o rings. |
11-09-2005, 05:08 PM | #6 |
Yes, all 68-87 will work, but as Andy mentioned (around 80/81 is what I remember) they went from SAE thread flared fittings on the hoses to metric thread o-ring connections. They make adapters so you can connect an SAE line to a o-ring/metric fitting and vice versa. Pitman arms only differ between power and non-power boxes. Also, as Andy mentioned the 73 and up had variable rate steering and quicker turning ratio's than our years. The 67 was way different from the others and I cannot for the life of me remember what made them so different.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 11-09-2005 at 05:09 PM. |
11-09-2005, 05:59 PM | #7 |
67 is sold
When I bought steering gear for my project truck, it said '1976 and previous' on the receipt
11-10-2005, 03:49 AM | #8 |
2wd & 4wd use different ones, though.
