Old 11-09-2005, 11:25 AM   #1
bucket
bucket's Avatar
paint codes
is there a source for interpreting factory paint codes? my glove box says my paint number is 4541AD. Looking at paint books i expected it to read 506 for medium blue.
bucket is offline   Reply With Quote
Old 11-09-2005, 12:06 PM   #2
Rod
Re: paint codes
Listing the year of your truck would make it easier to find for someone with a dealer data book and let you know.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-09-2005, 12:06 PM   #3
bucket
bucket's Avatar
Re: paint codes
sorry....1967 c20
Old 11-09-2005, 12:45 PM   #4
Rod
Re: paint codes
The 541 in the middle is the paint code..which is a two tone code which would mean your truck has medium blue ( metallic) and white.
The 506 code is same color just a single color paint job.....yours is 2 tone that's why the different number.
Old 11-09-2005, 12:47 PM   #5
Rod
Re: paint codes
The info I supplied is from the 67 dealer data book. I have all the years 67-72 in dealer data books.
Old 11-09-2005, 12:49 PM   #6
Rod
Re: paint codes
RPO's are sometimes done in 5 character codes..its no biggy once you learn to see what numbers letters actually matter. Only 3 matter mostly in these years.
Old 11-09-2005, 12:50 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: paint codes
In my '69 Truck Data Book, the following information is found, in reference to paint colors. I'll just list that for the light blue for that year ('69).
Chevrolet RPO number is 507
Du Pont number is 4537-L
Rinshed-Mason number is A-1688
Ditzler number is12486
Do you suppose that the number you cited, is specifically the manufacturer's number, as opposed to the RPO number you expected to find? Did you get the number from the data plate in the glove box? I would think that the RPO number would show on the data plate, but strange things apparently happen in the manufacturing process. It may be that the person who was in charge of creating the data plates used the paint manufacturers' number, instead of the RPO number...but, that is speculation on my part.
Member Nr. 2770
Old 11-09-2005, 12:54 PM   #8
Rod
Re: paint codes
That was strange...I saw your posts coming up 3 times there ChevLoRay..deleted the multiple posts and then got it back to one reply..strange, cause my replies were in time before yours but your replies were listed in time before and after mine..the times were messed up. Oh well looks better now.
Old 11-09-2005, 12:56 PM   #9
bucket
bucket's Avatar
Re: paint codes
sweet. thanks fellas! You are right Rod....the truck is two-tone. so if i have the 506 blue, what is the code for the white?
chevloray, the code was found on glovebox sticker in the box labeled "paint"
Old 11-09-2005, 01:51 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: paint codes
Rod, I didn't find specific codes listed for two-tone, as in anything but a three digit number in my '69 book. Unless the number I listed is for a specific paint manufacturer, I find nothing but 3-digit RPO codes. Where did you get the five-digit number, and how did you know that only the three center digits matter? I'm only asking to learn how to decode the info in the book.
On page 5, of the Cabs, Bodies & Colors section, dated November 8, 1968, my book lists color options for series 10-60 conventional cab and series 10-20 Chevy Van models. In all cases, as far as I can tell, the secondary color is always white. I am understanding that in the case of Black, a solid color truck would be an RPO 500, while a conventional two-tone (black/white) would be RPO 530. The Special Two-Tone code would be RPO 586....and ONLY if it had RPO BX2 custom side lower mouldings or RPO Z84 Custom Sport Truck. So, two-tones meant that only the top color was white in a convention two-tone, and the top as well as the lower body portion (beneath the lower side moulding) were white, at least in '69 and (I'm guessing) for '70.
Anyway, it's a good post and very informative reading.
Member Nr. 2770
Old 11-09-2005, 10:06 PM   #11
Rod
Re: paint codes
521 is the white.
As for 5 didgit codes..well its just developed learning I guess. If you study enough option stickers you'll see the prefix and suffix letter do change betwen assembly plants, so its not a standard practice IIRC.
As for the paint codes in 69 the top being white was called conventional two tone.
Old 11-09-2005, 10:13 PM   #12
Rod
Re: paint codes
I would like to get further into paint codes but not tonight too buzy.
It gets more confusing and I dont want to confuse people. Just a note that conventional two tone paint as a phraze means different things in different years and its different between blazer / suburbans and truck. Conventional two tone means different things. In 1970 Conventional two tone on a truck means white top, while conventional 2 tone on a blazer or sub means medium tone of main color used for secondary color.
I'll see if I can back to this post tomorrow.
Old 11-09-2005, 10:14 PM   #13
bucket
bucket's Avatar
Re: paint codes
thanks again.
Old 12-06-2005, 11:16 AM   #14
Ron
Ron's Avatar
Re: paint codes
Here's one for you. My paint code is 04514AA, truck is a 67 C-10. What colour is it called and was it two tone? Thanks
'69 SWB
'76 International "Terra"
"Hooked on holiday beer"
Ron is offline   Reply With Quote
Old 12-06-2005, 01:50 PM   #15
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: paint codes
514 was simply called "Red"
http://autocolorlibrary.com/cgi-bin/...truck-pg01.jpg
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-06-2005, 06:16 PM   #16
junkyarddog1956
junkyarddog1956's Avatar
Re: paint codes
Mine is 514 ...PPG calls it " Signal Red " ... kinda looks like a Stop Light ...lol... Joe
69 Chev C-10 ... painted and ready to reassemble ( for sale )
82 Custom Deluxe ( have parts to restore )
junkyarddog1956 is offline   Reply With Quote
