C10 Collector
Laying out the 72
Hey guys,
My truck is already bagged on 20's (27" tall tires) with air rides control arms and two inch dropped spindles. It lays the crossmember but I think I want to go to the frame. My Questions are about the front. I think I'm going to crossmember drop it 1.25 inches to keep stock steering, then Z it 2 inches or so to get that last bit. Will this get the frame down?? Also will I run into problems with the tubular upper control arms and the steering shaft?? Thanks guys, Ryan |
Re: Laying out the 72
Air out your truck and measure how far off the ground your frame is right behind the firewall. I suspect it to be less then 3 inches. Notch your crossmember 1.25 and Z the difference of it. Unless you plan on running bigger tires that will do. Also check what else hangs below your frame rail....ie your trailing arm crossmember, rivets on the frame...
Another thing...if you can't see under your truck to measure the frame jack it up level and put some 4x12 blocks to get it up off the ground 3.5". Hope this makes sense. |
C10 Collector
Thanks for the reply.
The problem is the truck is on jack stands right now. So I was looking for a round about measurement. When I do it I'll drop the crossmember then mount it and measure for the Z. ANyone have any idea about the steering shaft?? |
#4 | |
Seņor Member
XXL Am I reading this correct. You cut and dropped your front crossmember 1.5 inches. And other then adding 2 swivel joints to the steering box shaft, thats all you had to do ? I thought you had to do more. Like maybe re locate the steering box. and tie rods to clear. Your steering does not hit your frame ?
#6 | |
Seņor Member
Thanks for the help. Just one other thing. Once when I was at a swap meet I saw a 71 sitting low in the parking lot. I looked under it. And The lower A-frame was bolted up diffrent. The guy was not around so I could not ask. The lower A-frame instead of bolted up by the factory u-bolts to the bottom of the crossmember. There was a plate bolted up to the crossmember were the u-bolts went, then the lower A-frame was bolted up to it. Which let the lower A-frame be on each side of the crossmember and not the bottom. I am sure the reason for this is so the bottom a-frame would be higher off the ground. Is this a bracket that you can buy,or something that has to be made up.
#8 | |
Seņor Member
#9 | |
#10 | |
Do a 'Z' if you need a lot.
#11 | |
Seņor Member
#12 | |
#13 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
