Old 11-09-2005, 02:20 PM   #1
krazy_texan
krazy_texan's Avatar
trans bellhousing?
if i remember correctly the trans in my 67 is an sm465 heavy duty 4spd it is currently mated to a 350 do i need to get a new bell housing to mount it to a 292 or am i able to keep and use the same bellhousing that i have
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 11-09-2005, 05:15 PM   #2
Re: trans bellhousing?
I believ you'll need the new bellhousing, because of the crossmember being part of the bell housing. The mount in different locations on the frame and the 6 won't fit in the 8 position & vice versa.
If you were going the other way, 6 to 8 and wanted to mount the 8 in the 6 position, then they work fine. The bolting to the engine is not the problem, it's the housing to the frame that is the problem
Old 11-09-2005, 09:07 PM   #3
krue
Designated A-hole!
krue's Avatar
You could always slide the crossmember to the needed position, but that may prove to be more fun than you want.
On further thought, I remember when I was a wet behind the ears kid, I threw a 350 in place of a 250 and I didn't swap anything else other than fab a new exhaust (WAY OVERSTATING THAT more like rigging a get by exhaust) and moving a few wires. I don't see why you couldn't go the other way, but I've been wrong before.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-10-2005, 01:02 PM   #4
krazy_texan
the 350 is in place of a sixer because i did not want to move the crossmember so i am thinking that it should work which could be a good thing on my part and save me alot of time and headache on my part.
Krazy Texan
1990 v1500 suburban
Old 11-10-2005, 03:42 PM   #5
krue
Designated A-hole!
krue's Avatar
You ought to be fine then.
www.daveramsey.com
