Old 11-09-2005, 11:36 PM   #1
Desert Rat
Desert Rat's Avatar
6cyl Power Steering questions
Hi everyone. I was hoping someone could inform me on exactly what years of 6cyl power steering pumps and brackets will work on our trucks. I picked up a 69 with a 250 with a rebuilt motor and plan to leave it this way for a while until funds are available. Any idea what years will work? other applications like Chevelle, Nova, Impala. I have never messed with a 6cyl before any suggestions? Im sure this will be a tough one to find a/c brackets will be even harder, atleast it has a 3.73 posi!
Desert Rat is offline   Reply With Quote
Old 11-10-2005, 12:19 AM   #2
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: 6cyl Power Steering questions
I got a pump/bracket setup off of a 79 impala & it fit fine. Get the pump/bracket, the dual groove waterpump pulley, the belts & the hoses. I installed a ps setup a week ago & the only hitch was that I had to redrill the holes in the pulley to a different pattern but this was no big deal because the pulley is located off of the pump shaft & the bolts merely hold it inplace. I think the big thing to avoid is the integrated-head sixes like the plague! you'll know them by fact that the intake & head are cast together as one piece. the carb looks like a twobarrel or something. the only thing they are good for is their hei distributors. no brackets work from them. as for AC, bracket setups are rare & since the compressor sits JUST above a points distributor, it will not work with an hei because they are too tall
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 11-10-2005, 12:35 AM   #3
shifty
Questionable
shifty's Avatar
weren't the integrated head inlines mostly a mexico-only deal? i guess you'd need to watch out for that in AZ, but i'm just curious for clarification's sake...
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-10-2005, 12:54 AM   #4
passthebuck
there are a pile of integrated head L6's around here. i've seen them mostly in trucks & vans.
passthebuck
#5642
Old 11-10-2005, 02:18 AM   #5
shifty
Questionable
shifty's Avatar
Ok, so maybe it was a Canada/Mexico thing.
I dunno why I have Mexico stuck in my head. It's possible all the integrated head engines were just manufactured there, but distributed worldwide or something. I don't usually get stuff stuck in my head like that for no reason. I just usually can't figure it out!
Old 11-10-2005, 02:11 PM   #6
Micah....as long as you get the stuff from a non integrated head 230/250, it doenot matter what vehicle it came from. The 292 I think the brackets are a bit different because of the differences in deck height. Most of your 250s installed after 79/80 time frame are the integrated heads. Shifty they were originally designed for Mexico (and made there) but integrated with US during the heavy Tree hugger years of the .80s
Old 11-10-2005, 10:26 PM   #7
Desert Rat
Desert Rat's Avatar
Thanks for the response. The manjual steering box is junk and I hate to bolt a manual back on. I'm thinking 6cyl 4 spd, ps, pb, ac, tach, tilt. LOL.
Old 11-10-2005, 10:52 PM   #8
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
A few pics of mine
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 11-11-2005, 12:15 AM   #9
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Watch the spacing on the grooves on the pulleys. Most later 73+ inline sixes had wider spacing between belts. Look for all pulleys having the same spacing as your current crank balancer (you need two grooves on the crank for ps). You can sometimes use all of the pulleys, incl crank, and make the later system work...if you change everything. Good luck. I need one too.
PICKMUP is offline   Reply With Quote
Old 11-12-2005, 10:24 AM   #10
Desert Rat
Desert Rat's Avatar
I found one yesterday on a 77 Nova. I noticed the water pump pulley had more spacing, but I thought maybe I could change the pulley on the ps pump? I bought the pump and brackets for $20 and he wanted $25 for the water pump pulley. go figure? I don't have the extra cash to blow on a $25 pulley, but I suppose I will be going back for it next payday-LOL. I also bought a ps box for $25. I should have spent the $25 and put a manual box back on it for now from the first of 5 wrecking yards I went to. Bought 5 ralleys at $5 a piece.
Old 11-12-2005, 10:27 AM   #11
Desert Rat
Desert Rat's Avatar
botietruck- that is one sweet 6cyl and frame! I hope I can find those A/C brackets! I'm sure someone here in Arizona with a 6 had air.
Old 11-12-2005, 10:50 AM   #12
His engine is beautiful, but just in case you didn't know the AC won't fit if you are running an HEI distributor.
Old 11-12-2005, 11:06 AM   #13
Lgriffin
An early 74-76 HEI with the separate coil will fit.
Larry
Lgriffin is offline   Reply With Quote
Old 11-12-2005, 11:11 AM   #14
Cool. I did not know that.
Old 11-12-2005, 12:23 PM   #15
Desert Rat
Desert Rat's Avatar
I will certainly relieve it of it's HEI to keep cool in the summer.
Old 11-12-2005, 01:52 PM   #16
Botietruck
Botietruck's Avatar
Thanks for the comments.
I switched my to the Pertronix system.
Old 11-12-2005, 02:14 PM   #17
Americanrider
Good 6 cly info..... one of you guys should write up a post for the FAQ's.
Americanrider is offline   Reply With Quote
Old 11-12-2005, 11:35 PM   #18
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Hey Micah,
I got mine today from a Nova guy. It is the correct early small round can. You will probably need a double wp and a double alt pulley. If you get the same/correct set the alt belt is going to move to the outside and ps will run on the inside (where your alt is currently running). That little switch has fooled too many guys.
The assembly manual shows the setup, however poorly.
I will post pics of this setup before and after...got to blast & paint first.
It is identical to this one.
Old 11-15-2005, 10:03 PM   #19
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Micah, how's it going?
Here is the before...
and here is the after. OK, I am not doing so good on the after...been a little busy detailing inside cab & under hood. Maybe later this week. Going to use the later variable/quick ratio box with the bigger stock steering wheel.
I think small wheels & quick ratio can be a little too much and a little radical. The stock ratio box seems to feel better with the small wheels.
Old 11-15-2005, 11:41 PM   #20
moodybo
moodybo's Avatar
I installed a integral head power streering bracket on a non integral head last week. I will get some pictures of the work tommorow. It is not proffesional but it works!
moodybo is offline   Reply With Quote
Old 11-16-2005, 09:12 AM   #21
Canadian72GMC
pictures would be great. I may have to do the same thing.
Canadian72GMC is offline   Reply With Quote
Old 01-13-2007, 08:48 PM   #22
nvrforgotten52
nvrforgotten52's Avatar
does anyone have anymore information on this stuff... its really hard to find brackets that will work on the L6...
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 01-14-2007, 04:02 AM   #23
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
Man Iremember adding power steering onto my 250. I got so fed up of looking for a power steering pump bracket that my dad and I ended up making one out of aboutthree diferent types. It looked rediculous, but that belt never slipped. Same pump as what the guy up there is using too.
Those 'seperate coil' HEI distributors can be found on Chevy/Pontiac cars of the late seventies. I remember seeing one on a car called the Pontiac Ventura. You may even find A/C brackets on these engines that fit, but don't take my word for it. I sold the inline 6 and dropped in a V8. Hard to conform, but well worth it.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
