Coil Overs
Ok I have a 70 Long bed 1/2 2wd with coils in the back. I saw a kit in jegs that has coil overs, and all the brackets to bolt them in. But it said for cars 3300-4000 pounds. So that wont work for my truck will it?
So what coil overs will I need then? I can always buy the brackets and just make my own cross member for the top.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
Gone Fishing
Re: Coil Overs
Try CPP I've seen a set up for our trucks in their catalog
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Re: Coil Overs
I bought mine from CPP and it all fit together perfect. They look good too.
![]() Join Date: Jul 2005
Re: Coil Overs
Cpp?
Re: Coil Overs
I would like to know what cpp is as well.
Project92 SWB stepside
Re: Coil Overs
You need the weight on the rear half of the truck not the whole truck.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
Gone Fishing
Re: Coil Overs
Classic Performance Parts
Re: Coil Overs
I did a set of QA1 coilovers from jegs. The adjustable shocks are nice. I used the 3000-4000 # kit and it works great! Dynoed the truck last week at 655 Rear wheel horsepower, and using only drag radials, it literally pulls the front end of the truck off the ground. I give most of the credit to the QA1 adjustable coilovers.
67 Chevy SWB - goal of a 1,000 hp weekend cruiser |
Re: Coil Overs
How are those bottom brackets on there? Those are adjustable right, so I can set the ride height at different heights.
Saving 1 truck at a time!
Re: Coil Overs
"...it literally pulls the front end of the truck off the ground..." Gotta see pics of that...WOW! Great looking truck and nice work!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Re: Coil Overs
I have the qa1's on my dragtruck and had them on my street truck also! I also put them on my uncle's 66!
Love them. Kevin
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#12 | |
Re: Coil Overs
I bought the whole kit, and they are ride height adjustable. The lower brackets weld onto the axle housing, and the upper you have to put in a new crossmember for. It's quite tedious work getting all the geometry right when setting them up, definatly somthing you don't wanna rush through. as you can see in the pic, i also have an adjustable panhard bar too, that is relocated for the lowered truck, and moved to clear the coilovers, which is a real tight fit.
#13 |
Re: Coil Overs
I would recommend the adjustable pan hard bar too but we mounted my uncle's in front of the rear axle and had plenty of room!
Oborny71 Your truck looks sweet how fast is it! You should post it on dragtruk.com if its not there! I don't remember seeing it there! Kevin
#14 |
Re: Coil Overs
Here is a picture of my CPP kit. It was all bolt in.
#15 |
Re: Coil Overs
How much was the CPP kit?
#16 |
An American Soldier
![]() Join Date: Feb 2005
Re: Coil Overs
There website list a 3" drop coil over set for $499 and a 4.5" drop coil over for $549. Too steep for me..I just put in 4" drop springs. Here's a link to a tech article about installing them on our trucks:
http://www.classicperform.com/tech_a...coil-overs.htm
Dan dan.brue@us.army.mil |
#17 | ||
Re: Coil Overs
yeah, i don't have it posted on dragtruk. haven't been to the track yet with the new motor setup, but i'm shooting for some where in the mid 9s on boost and juice. this truck is mostly street driven Quote:
67 Chevy SWB - goal of a 1,000 hp weekend cruiser Last edited by Oborny71; 11-11-2005 at 08:25 PM. |
#18 |
Re: Coil Overs
[QUOTE=Oborny71]yeah, i don't have it posted on dragtruk. haven't been to the track yet with the new motor setup, but i'm shooting for some where in the mid 9s on boost and juice. this truck is mostly street driven
Sweet truck get that thing to the track and show us with details! The dodge boys started Dragtruk.com but we got to have more Bowtie's on there! Kevin
#19 |
Re: Coil Overs
Can anyone recommend which kit(QA1 or CPP) is better? From what I gather CPP is bolt-on and QA1 needs more work to install. Would this be accurate?
#20 |
Re: Coil Overs
Kevin[/QUOTE] Ya she's a regular dodge fest over there, I'm saving my entry for my new mill, it will be posted up when spring returns and the track opens. Hoping to have a pic with the wheels up to go along. ![]()
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 11-12-2005 at 03:05 AM. |
#21 |
Re: Coil Overs
Alex,
I would go with the Qa1 for racing! If its just a street truck it would probably be fine either way!
#22 |
Re: Coil Overs
DJ, Thanks for the response!!!! It will be a 1/2 ton with a pretty stout 406. Approximately 500hp. Does that change the answer?
#23 |
Re: Coil Overs
I'd lean to wards the qa1 route! I've had them on 3 trucks and the adjust ability is nice. qa1 makes them both ways so I'd get them adjustable! I also prefer the look of the more custom route. I'd get the cpp adjustable track arm bar!
Kevin
#24 |
Re: Coil Overs
Thanks again...good advise.
#25 |
Re: Coil Overs
Do you think coil overs will help my traction alot? I was out at the track tonight with my truck and one run was a 20 because I spun through first and all through second. And every run I had to baby it off the line and the best run was a 16.95 with some sliping.
