11-10-2005, 08:22 AM | #1 |
Lookin for a pic with rally's or ?
Hey folks,
I'm running 6.6 or 7" rallys now with bfg at 235/75/15's. I know these tires are for 4wd's. I have a set of 8" rally's and rings ready to go, but with the current situation I'm in. I'll have to use these tires for another year or two. So does anybody have a pic of their 2wd vehicle with 8" rally's and 235's?? I also have a 2/4 drop. Or should I just wait and drive around on these. And hope for a good deal to pop up. Right now the local shop will swap and balance for $8 a piece. bob
1986 C10 Scottsdale 5.3, TH400 |
11-10-2005, 09:15 AM | #2 |
yeller
Re: Lookin for a pic with rally's or ?
Here is the '76 2wd I had. It has the 8" Rally wheels and some larger tires on it. I am not sure about the size since I got them from a friend, but they were on his 4by Ford truck.
Hope it helps.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
11-10-2005, 09:33 AM | #3 |
STILL PLAYS WITH TRUX
This pic is from 1987 when i got the truck and kinda faraway but here it is.
11-10-2005, 09:51 AM | #4 |
Thanks guy's. Do you rember if the wheel/tires on the 8's filled the wells out. What I mean is, did the tires come closer to the fenders?
I have what is known locally as the "scared cat" look. thin tires tucked in way to much under the sheet fenders. bob
11-10-2005, 10:28 AM | #5 |
yeller
It filled them out well, remember, the rear track width is narrower than the front..they came this way from the factory. Here is another pic to give you a visual.
11-10-2005, 01:42 PM | #6 |
I had org. rally's but they were beat up, got these off an obs pickup. Very similar, they are now black with black caps, ill post new ones later Last edited by billybob750; 11-10-2005 at 01:43 PM. |
11-10-2005, 04:00 PM | #7 |
www.73-87chevytrucks.com
This is my Stock 1987 with stock size tires:
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
11-10-2005, 08:28 PM | #8 |
On my 84 Im running 7's in the front & 8's in the rear. The only difference is 1/2" out & 1/2" in. I used the 7's in the front to clear my lower control arms with the drop spindles...corn
I was going to post a pic but the site wont let me right now. Ill try again later... |
11-10-2005, 09:25 PM | #9 |
cornfed what size tire you running?
capt I could probably live with your set up. Nice truck. thanks all for the pics. I really can't nail down tire sizes for these trucks. The rims I have I know were not orig to the truck say's the PO. They are narrow. That's why I got the 8" Size (height) I really like these 235's but when you look from the back they are really tucked under there. thanks bob
11-10-2005, 09:34 PM | #10 | |
11-10-2005, 09:36 PM | #11 |
HEy I just saw that BFG sells an AT 325/60/15. That's 12.9 wide and 30" tall. Ant thoughts If I just run these on the rear with my 8" rims and 235 up front. As I type I don't like the image in my brain..
bob
11-10-2005, 11:34 PM | #12 |
Insert Witty Text Here
I would not run over a 275/60/15 on an 8 inch wheel. Anything wider looks odd. A tire as wide as you mentioned might not even be safe on an 8 inch wheel.
I like the look of a 255/70/15 or a 275/60/15 on an 8 incher. You can see what the 255/70/15 tires look like on mine, lowered 2.5 inches in the front, on the pic at the top of my website. |
11-10-2005, 11:38 PM | #13 |
Im using 225/70 on the front & 275/60 on the rear...
11-11-2005, 12:51 AM | #14 |
here it is with 235/75/r15s
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 11-11-2005 at 01:02 AM. |
