Will a 72 K20 axle (dana 44?) fit on a 77 k10?
quick question- will a 72 k20 axle (dana 44?) fit on a 77 k10? Are the springs the same width apart, etc.? I owe the PO of my 77 stepside the front axle, and may buy a 72 k20 for parts. Thanks very much!!
Crosby 1978 Chevrolet K10 stepside NH |
Post Whore
![]() Join Date: Feb 2000
Re: Will a 72 K20 axle (dana 44?) fit on a 77 k10?
Yep, the front axle will bolt right in place with no mods. The rear axles do have a different spring width though.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
excellent, thank you! Isn't the 72 the closed knuckle design (less desirable?)
Post Whore
Nope. The 69 was the last year that you should find the closed knuckle Dana 44.
So it should be the same then as my 77ish K20? Not a bad axle if you ask me. Just a step below a dana 60. This 72 does have the useless Eaton rear. I think the frame and running gear is original, after looking at it yesterday. Thanks Jack!
#6 | |
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Sorry Adam, no offense meant. Just saying that for the purposes of buying this truck, that's not a high demand part (I don't believe). Let me know if you want it
#8 | |
Keep in mind the 72 d44 uses smaller shafts andu-joints and the hubs don't seal worth a ****. Just let him know its out of a 72 so when he needs parts he won't be baffled.
DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
Hi Doug. No, I was going to use the 44 to roll around what was left of my 77, that's all. Thanks for the info!
