Old 07-09-2002, 07:12 PM   #1
flyin99
creator of kong
flyin99's Avatar
Talking Please look guys.I need your input on this one!!!
Need your input on if my wheel studs on my back wheels are long enough.they come through the wheel and stop at the edge....there is NO thread sticking through.............if I use long shank lug nuts, will this be ok? I called Weld and they said if I can turn the nut 7 turns, it doesn't matter if it sticks through the wheel or not......hmmmmmmmmmm.......that just sounded odd.maybe it is true.....what you all think?
flyin99 is offline   Reply With Quote
Old 07-09-2002, 07:16 PM   #2
72Lester
Genuine smartass
72Lester's Avatar
That looks scary to me. 7 turns or not, I'd still want the threads to at least come all the way through the nuts. Not to mention that fact that the threaded portion of the stud is now load bearing, which is never good.
'99 Chevy 3/4 Burb 4x4
'98 Chevy 1/2 Short Bed 4x4
Former 67 & 72 owner
Wanted: 1972 10 or 20 4X4, V8 4spd
72Lester is offline   Reply With Quote
Old 07-09-2002, 07:19 PM   #3
dion
72 Cheyenne
dion's Avatar
I wouldn't.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 07-09-2002, 07:22 PM   #4
Tim Christian
Tim Christian's Avatar
Just put longer studs in.
Tim Christian is offline   Reply With Quote
Old 07-09-2002, 07:39 PM   #5
Als454
I'm with Tim. Get longer studs. I bought a car once with after market wheels on it. Drove it about 50 miles, felt a slight vibration, right front wheel fell off. Lugs were to short.
Trust me if you don't fix it. It will bother you everytime you drive.
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 07-09-2002, 07:40 PM   #6
68 with 350 TPI
68 with 350 TPI's Avatar
Just take off one wheel stud so you can take it to NAPA and match it up with a longer one.
Get a set and change them out.
Very easy to do with a hammer to knock them out.
Then to put them on use a old nut that will fit the new studs with a washer behind it. Just tighten them up until they bottom out and your done.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-09-2002, 07:51 PM   #7
lux hauler
Psycho-billy Member
lux hauler's Avatar
the correct length lug nuts that extend through the wheel should be ok but if I was going to be driving it, I'd get longer studs
it is a good idea to use the long shank nuts to keep the wheel from rotating front to back and to distribute the torque throughout the stud.
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 07-09-2002, 08:03 PM   #8
Wabash
Wabash's Avatar
that dont look good at all
my rule of thumb is to have at least 2 threads sticking out of the other side of the nut just too be sure.
and it isnt that bad to change the studs out if you dont want to do it get your local tire shop to do it it wont take but a few minutes.
1972 C/10 LWB
1972 K/5 Blazer
Wabash is offline   Reply With Quote
Old 07-09-2002, 08:27 PM   #9
Randy70C-10
Randy70C-10's Avatar
Yes, get longer studs, but get the correct lugnuts too. If I remember correctly, you should be using 2 1/2 inch lug nuts.
Randy70C-10 is offline   Reply With Quote
Old 07-09-2002, 09:37 PM   #10
Wasted Income
Boosted Member
Wasted Income's Avatar
Don't use those studs. You're just asking for trouble if you do.
I believe that the IHRA rulebook states that studs must be sticking through the lugnut by at least a length equal to the diameter of the stud.
You probably won't be racing it, but hey, what's safe for racing use is safe for the street (as far as equipment goes).
-Jeff
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 07-09-2002, 10:05 PM   #11
Danny69'
I personally would change it. Better safe then sorry.
1969' LWB [Work in Progress]
Danny69' is offline   Reply With Quote
Old 07-09-2002, 10:17 PM   #12
weasel29gm
SLOW BUT SURE,BUT CLOSER
longer studs, rather be safe than sorry!!!!!!!!!
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 07-09-2002, 11:04 PM   #13
racedvl
racedvl's Avatar
Get longer studs. Can't play too safe....
racedvl is offline   Reply With Quote
Old 07-10-2002, 01:50 AM   #14
Radiatta_71
Radiatta_71's Avatar
If this helps any. The proper thread engagement for a threaded fastener is 1.5 X the bolt diameter. I would def. get longer studs.
Rad.
Radiatta_71 is offline   Reply With Quote
Old 07-10-2002, 02:11 AM   #15
Hooter
My other Love
Hooter's Avatar
i have had mgs on my 74 for a while. the studs dont stick out through the mags so i have those lug nuts that go into the rim. i have had no problems so far
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 07-10-2002, 03:37 AM   #16
damage
Yeah, same here. Had a set of center line mags on my 76 Z/28. The lugs were flush with the rims. The lugs went into the wheels and almost touched the base of the lug. When the wheel is off, insert a lug and see if it pretty close to being flush with the back side of the wheel. If so, you should be alright. My wheels were two piece, and from the looks of it, your are too. If I remember right, mine were pretty thick though, inch and a half, maybe more.
damage is offline   Reply With Quote
Old 07-10-2002, 08:57 AM   #17
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
While mechanically there will be no difference if you get longer studs. Your lug nuts will bottom out on the rim and this is where the side load will be felt. Once you reach the outer edge of the rim (which is where your studs are), they're just extra threads. Probably the reason racing rules say have extra threads is to keep the wheel on if the lugs back out a bit. That won't be an issue with long shank lug nuts, not all racers use those so the rules have to cover everyone. I know most of you won't agree but think hard about it. If I were you though, I'd get new studs for piece of mind. Plus, I heard a rumor that I was wrong once. People will talk! LOL
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 07-10-2002, 09:40 AM   #18
jku72
Just one wheel bouncing off down the road, hitting some lawyers BMW will convince you. Maybe you will be safe as is, but if you are wrong, and sombody gets hurt, you will be extremely sorry you pinched pennies. Canging the lugs is so easy, each one takes a bout 1 minute, I think there is no eal justification for not changing. To change them, just find an old nasty lug nut, thread in on, but not all the way, make sure the lug is still recessed in the nut, and wail on it with a dead blow, and it will pop out the back side. Then since the nut was only on hand tight, remove the nut from the lug, and toss the lug away. To install a new one, just slide it through the hole as far as it will go, then draw it the rest of the way in with a lug nut, until it is fully seated. I have about 20 this way, it is quick, easy, and safe.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 07-10-2002, 09:54 AM   #19
Low69CST
I'd go with longer studs, I've seen all the other work you've done to your truck, why go cheap on studs. Nice truck you have, it'd really look bad riding on one of the fenders doing 70 down the interstate.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-10-2002, 10:52 AM   #20
Smooth68
Smooth68's Avatar
<----------Someone ask for a longer stud?
No, seriously I'm with the majority - go ahead and do the longer studs. I was in the same boat with my u-bolts on the rear, and I got longer ones! Better safe than sorry - especially with a nice truck like that.
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
