Van AM/FM radio install ??
Does the van AM/ FM have the same dimentions as a truck radio. What keeps the shafts secured and centered in the dash? In the van the radio mounted like a modern shaft radio with the monting hole just slightly bigger than the shaft and held on with a washer and shaft nut. In my 72 truck the dash shaft holes are much bigger.
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. |
More Cowbell....
Re: Van AM/FM radio install ??
Trucks require a recessed metal "cup" that basically reduces that hole size. I can't find my picture of it, but maybe someone will post it in a little while. They can usually be found on the parts board if you post a Wanted thread.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
