Factory Engine Oil Cooler Lines
Hi all, I have a 1986 Surburban with the factory engine oil cooler everything is good cept for the oil lines that go from the adapter to the cooler, does anybody know of a replacement line I can use?
Thanks in advance |
Active Member
Re: Factory Engine Oil Cooler Lines
can get new from gm wlpmtp@verizon.net
I bought sime time using generic oil line over the barbed fittings, but ended up installing original GM lines from the dealer eventually.
Semper Paratus |
I went to a hydraulic shop and bought two saginaw to AN fittings for the oil cooler end then used brass 6 AN fittings for the oil cooler adapter.... then used rebuildable aeroquip fittings to make my lines to the desired length. Unfortunately i've found the gm lines don't last as long as they should.
Doug W.
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
