11-10-2005, 04:34 PM | #1 |
Prop. Valve ?
Are the factory proportioning valves rebuildable? I'm asking about one for disc brakes.
11-11-2005, 12:18 PM | #2 |
its all about the +6 inches
Re: Prop. Valve ?
Pretty sur ethey aren't, and persoanlly, even if they were, I wouldn't.
11-11-2005, 09:45 PM | #3 |
Franko72
Re: Prop. Valve ?
I have never heard of a rebuild kit either. I removed one from a jeep once and disassembled it. It was dirty on the inside and the o rings were wore. I cleaned it up and reinstalled it. It worked fine for about a month. ended up buying new one.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
11-11-2005, 09:52 PM | #4 |
Re: Prop. Valve ?
Tim, I have not seen a kit to rebuild them but do know they are available as rebuilts or new --but they are pricy. You can use an adjustable one that are available in the aftermarket---street roders use them all the time. About $40-50. Sometimes you can pick up a good original in a pick&pull cheap. Make sure it is for a disc-drum setup as drum-drum are different. Huck
