Old 07-09-2002, 07:32 PM   #1
Als454
Question Truck won't shut off
Truck has HEI wired to IGN unfused at fuse box. When I turn the key off it runs for another 5 to 10 seconds then shuts off.
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 07-09-2002, 08:03 PM   #2
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
its not runnin too rich and just dieseling because of that is it?, my radio keeps playin for 3-5seconds after I shut it off, itswired to acc fused
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 07-09-2002, 08:24 PM   #3
Randy70C-10
Randy70C-10's Avatar
Advance the timing a little and see if that fixes it.
Randy70C-10 is offline   Reply With Quote
Old 07-09-2002, 10:07 PM   #4
Danny69'
Do you have an electric fan? I know my truck has trouble shutting off when it's on. I'm getting around to fixing it soon.
1969' LWB [Work in Progress]
Danny69' is offline   Reply With Quote
Old 07-09-2002, 11:12 PM   #5
RipMeyer
RipMeyer's Avatar
I have ALL OF A SUDDEN developed this problem and I just recently installed electric fans. The fans and HEI are sharing the same power plug on the fuse box.
Hmm I wonder
BTW its not deiseling
RipMeyer is offline   Reply With Quote
Old 07-10-2002, 01:10 AM   #6
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
The electric fans will do it. Distributor and electric fans must not be connected in any way.
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 07-10-2002, 03:59 AM   #7
damage
Please explain the logic behind all this. Are the fans holding enough charge to feed the HEI for a couple of seconds? My truck did the same thing a while back when I converted to HEI. After changing the resistance wire so the HEI could pull 12 v I had no problem. I still don't understand what was holding charge then.
damage is offline   Reply With Quote
Old 07-10-2002, 04:40 AM   #8
Patrick Sullivan
After you turn the ignition off, the electric fan doesn't stop spinning immediately. For the 10 or so seconds it is still spinning, the fan itself is acting as a generator, feeding energy back up to your ignition system.
This Cartalk Puzzler explains in more detail.
Old 07-10-2002, 06:35 AM   #9
damage
But to generate that much power amazes me. Well I guess it isnt really all that much. An electric motor works with magnets on the outside with a commutator in the middle. An electro magnet is created in the center pulling the comm around. Now the generator has electro magnets on the comm and outside correct?? interesting none the less...
Old 07-10-2002, 06:53 AM   #10
Patrick Sullivan
Aye, it confuses me as well. I'm gonna have to try it when I get an electric fan..
Old 07-10-2002, 11:46 AM   #11
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
It could be a problem with your alternator, like the diode trio. disconnect your ammeter/volt meter and see if you still have the problem, they can supply voltage to the engine through the guage and keep it running.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 07-10-2002, 12:23 PM   #12
John Fabris
TOTY 2006
John Fabris's Avatar
GMCJunkie's hubby's truck is doing the same thing, and he says it is the electric fan. He showed this to me last weekend when I went out to pick up the rear A/C parts for a suburban.....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 07-10-2002, 05:12 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Its true, the fans will do it. At an idle, it only takes about 4 volts to fire the ignition....way less if you still have points. The fan(s) can, and do produce this kind of voltage.
John, you are one lucky b@stard.
Old 07-10-2002, 10:41 PM   #14
Als454
Thumbs up
Thanks Guys!!!!!
It was the electric fan, had it wired into the hot to distributor.
Old 07-10-2002, 10:44 PM   #15
Southpa
Southpa's Avatar
Its either running too rich or your idle is set too high. Knock it down a little and see if the problem persists.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
