pcv
I got the pcv for my motor year and it points striaght up the one in the truck now has a 90 deg bend does it matter? or should I use the one that points up? What ones are others using?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Re: pcv
Same thing really. I like the 90's, but if I remember you can pop the plastic 90 off of your old one & there is a straight pvc valve under it. Snap it on your new one & away ya go...corn
Re: pcv
I have alot of oil in my hose wondering if I go up a little way then put an elbow in it if it will help.
Re: pcv
OEM was a stright up one with a 90 molded in the hose.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
Cantankerous Geezer
Re: pcv
The 90 works better when you don't have the bent hose. Either one will work, though.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Re: pcv
I use the straight PCV's and just cut the hose longer to make up for not being molded 90 degrees. Works good and I don't have a problem with it pulling oil up the hose.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Re: pcv
hoping maybe the straight up will help my oil problem also.
Its Magically Delicious
Re: pcv
you need a valve cover with baffles to keep the oil out of the hose
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
Re: pcv
ya not sure I have tall covers and they bearlly clear the rocker arms
