11-11-2005, 02:06 PM | #1 |
Stupid Question??
How do I tell if my burb is 1/2 or 3/4 ton? Thought it would say on vin or title. It's a 2wd coil rear. VIN is CE169Z877268 if that helps. Thanks for any help.
CPO U.S. Navy(Ret) 1972 GMC Jimmy 4x4 Custom 1972 GMC Jimmy 2x4 Custom |
11-11-2005, 03:22 PM | #2 |
Re: Stupid Question??
3/4 tons have 8 lug wheels.
11-11-2005, 03:54 PM | #3 |
Junior Member
Mine is a 69 3/4 ton 2wd and it's 6 lug
2006 GMC Sierra 1969 Suburban -For Sale- |
11-11-2005, 08:43 PM | #4 |
Roadtrip!
6 lug wheels = 1/2 ton through 70
5 lug wheels = 1/2 ton 71 and 72 (unless 4x4, still 6 lug.) 8 lug wheels = 3/4 ton. 2 or 4 wheel drive.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
11-11-2005, 08:53 PM | #5 |
Junior Member
hmmm wonder why mine is only 6 lug then
11-12-2005, 04:28 PM | #6 |
PO may have changed out axles for more rim chocies,
Earl 68 2500 4x4 GMC Burb |
11-12-2005, 07:01 PM | #7 | |
Born a Chevy Man
Are you sure your Burb is a 3/4 ton?
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) CHEVY, American made w/pride! If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
11-13-2005, 10:52 AM | #8 | |
Where's my beer?
Your 'burb has the correct lug pattern, '67-'70 had 6 lugs drum brakes all arround for a 1/2 ton, for a 3/4 ton it had 8 lugs all around regardless of the year, but in '71 they came out with the disc brake on the front (this disk upgrade applies for all trucks regardless if it was a half ton, 3/4 ton or a 1 ton) Now for 4X4, all 1/2 ton ('67-'72) were 6 lugs with the disc change in '71 as mentioned above. |
11-13-2005, 10:54 AM | #9 |
Where's my beer?
BTW, does your 'burb have a C-10 or C-20 badge? c-10 is a 1/2 ton and C-20 would be a 3/4 ton.
11-16-2005, 01:24 PM | #10 | |
Check out GMTrucks.org
Here is the breakdown: C = 2wd E = V-8 1 = 1/2 ton 6 = suburban? 9 = 1969 Z = Fremont assembly plant. The rest is the serial number. |
11-19-2005, 05:01 PM | #11 |
Thanks for the responses.
11-29-2005, 01:35 AM | #12 |
As in a previus post broke it down to a 1/2 ton I thought some that don't have a decoder would like this; 1967-1972 VIN Number Codes Example: CE149J 100001 # Chassis Designation (1st digit) C= 4x2 # K= 4x4 # Engine Deisgnation (2nd digit) E = V-8 Gas # S = Six Cylinder Gas # GVW Range (3rd Digit) 1 = 1/2 Ton # 2 = 3/4 Ton # 3 = 1 Ton # Model Code (4th Digit) 4 = Pickup with Cab and Bed # Model Year (5th Digit) 7 = 1967 # 8 = 1968 # 9 = 1969 # 0 = 1970 # 1 = 1971 # 2 = 1972 # Assembly Plant A = Atlanta # B = Baltimore # F = Flint # J = Janesville # N = Norwood # P = Pontiac # S = St. Louis # T = Tarrytown # Z = Fremont # 1 = Oshawa # Vehicle Serial Number 100001 = 1st Unit Built 1967-1972 Model Number Codes (The Model Number is located on the inside of the glove box door.) Example: C E 1 09 9 34 J 100001 # Chassis Designation (1st digit) C = 4x2 # K = 4x4 # P = Forward Control # Engine Deisgnation (2nd digit) E = V-8 Gas # S = Six Cylinder Gas # GVW Range (3rd Digit) 1 = 1/2 Ton # 2 = 3/4 Ton # 3 = 1 Ton # Cab To Axle Dimension (4th Digit) 07 = 42"-47" # 09 = 54"-59" # 10 = 60"-65" # 12 = 72"-77" # 13 = 78"-83" # 14 = 84"-89" # 15 = 90"-95" # Model Year (5th Digit) 7 - 1967 # 8 - 1968 # 9 - 1969 # 0 - 1970 # 1 - 1971 # 2 - 1972 # Body and Brake (6th Digit) 02 = Flat Face Cowl # 03 = Cab # 04 = Stepside Pickup # 05 = Panel # 06 = Suburban # 09 = Cab, Platform, and Stake Rack # 12 = Windshield Cowl # 16 = Suburban (Tail and Liftgate) # 26 = Custom Suburban (Panel Rear Doors) # 34 = Fleetside Pickup # 35 = Foward Control (Square Front) # 36 = Deluxe Suburban (Panel Rear Doors) # 42 = Forward Control Chassis # 45 = Forward Control Panel (Round Front) # Assembly Plant A = Atlanta # B = Baltimore # F = Flint # J = Janesville # N = Norwood # P = Pontiac (GM Truck) # S = St. Louis # T = Tarrytown # Z = Fremont # 1 = Oshawa, Ont., Can. # Vehicle Serial Number 100001 = 1st Unit Built THANKS EMMETT
Kaukauna WI Airplaines don't land here they are sucked down |
