Old 11-11-2005, 09:11 PM   #1
WestCoaster
Junior Member
WestCoaster's Avatar
Smile L31 Heads & Edel AFB = Good Times
Latest updates;
I completed the disk brake-front end conversion using a 1986 2WD, I converted everything and it took me about 7 hours to complete. Amazing to me was that the camber and caster were right to spec, toe was off 2degress on the drivers-side.
Another project was to install 1997 L31 heads. I found a good pair at the local swap meet for $50 ;-) I started at 9AM and was done in 6 hours. The process required tearing ever thing down to a short block and rebuilding the engine. I used the following;
GMC 1997 L31 heads
FelPro 0.041 Head Gaskets - REQUIRED
Edelbrock Performer Vortec Intake
MSD 6A Ignition and Distibutor
Stock head bolts and push rods
Edelbrock 1901 Carb
Sanderson Headers
R&M Sparkplugh Wire Loom
It was a very straightforward swap and I highly recommend it to anyone with a 1st Gen 350, the performance gains are impressive.
One issue that I and the local Q-Jet shop could not resolve was the fact that the Edel-2116 Manifold has no provision for exhaust heated chokes (i.e. the 1901) ;-( I had no choke............
Another area of frustration was the 1901 never seemed to provide the correct AF mixture even though we spent a weekend in the carb shop tweaking the 1901 Q-Jet and using the shop 5-gas analyzer and on the road testing with a SunPro AF gauge, the engine just never really responded like I felt it should.
After alot of frustrating work, I finally wanted to establish baseline for the carburetion, sooo, I went to Kragens and bought an Edel 1406 AFB, I know…I’ve heard it all. Anyway I bolted the AFB on in about an hour. I then started tuning, added the 4% richer rods and wow the engine came to life. The truck is very drivable and the power is just plain awesome. Highly recommended. oh I now have an electric choke..........
The next addition will be a MSD 8680 Timing Control for that on road "tuning" and maybe a alky-h2o misting system.
I’ll post that info as completed.
Thanks for the time, if anyone wants more info.........
Old Trucks = Good Times
WestCoaster
1970 GMC 2500
1994 S10 SuperSport
2000 16' Customweld FishN Boat
WestCoaster is offline   Reply With Quote
Old 11-11-2005, 10:23 PM   #2
GMan69
GMan69's Avatar
Re: L31 Heads & Edel AFB = Good Times
Sounds like you're havin' way too much fun.
George Morgan
Hernando, MS
'69 C-10 swb fleetside
'72 GMC swb Stepside
GMan69 is offline   Reply With Quote
