11-11-2005, 11:47 PM | #1 |
Swapping in 3/4 ton axles
I've got a 72 3/4 ton 4x4 pickup and am thinking about swapping the axles into the 71 Jimmy.
Anybody ever try this? Is it a direct bolt in or would some fabrication be required? Ron
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside) 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! |
11-12-2005, 08:22 AM | #2 |
Junk/Daily Driver Club
Re: Swapping in 3/4 ton axles
Should bolt rite in. Your high gearing might not be as good. HO72 4.10 at best.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker. There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened! |
11-12-2005, 08:27 AM | #3 |
The LuvShack Garage
Several members here have done 3/4 ton, some even 1 ton
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
11-12-2005, 10:04 PM | #4 |
The Blazer King
Our years are a direct interchange. All of the 73+ fronts are direct as well. 73+ rears need the spring perches moved. I have a 73+ FF 14 bolt in mine.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
11-12-2005, 10:23 PM | #5 |
Thanks! Now I just have to decide if I want to do it.
Ron
11-12-2005, 10:29 PM | #6 | |
The LuvShack Garage
BIGGER IS BETTER
11-13-2005, 02:25 PM | #7 |
Yup!
11-14-2005, 02:09 PM | #8 |
Junior Member
Go for it. I did it, so it must be simple.
11-14-2005, 02:31 PM | #9 |
www.clayharrison.com/truck/ '72 K5 "Georgia Red" Blazer (driver and dawg hauler) '72 Cheyenne Super C20 LWB (parts and projects) |
11-14-2005, 02:39 PM | #10 |
SKINNY TIRES RULE!
IF your going to be running big tires and going off-road a lot, go for it. You may have to make a different driveline (someone correct me if I'm wrong), but everything else should be straight forward. There are a ton of guys on CK5.com running 3/4 & 1 ton gear.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
11-18-2005, 01:01 PM | #11 |
The Crazy Kracka
The Brake components may also need to be changed, i.e. the Master Cylinder and the proportioning valve. There is a significant weight difference and clearance difference between a 12 bolt and a 14 bolt. If you don't care about that then you will be hard pressed to destroy the 3/4 ton equipment. I would do it if it were me.
My goal in life is to be as good of a person as my dog already thinks I am. 68 GMC LWB 396 BBC Camper Special 72 Chevy Blazer 4x4 with 406 SBC 73 Dodge Dart Sport with 340 |
