Old 11-12-2005, 11:14 AM   #1
brandonh
brandonh's Avatar
need help with suspension swap
i have a 69 chevy non disk brake 6 bolt and im putting 73-87 style 3 inch drop spindles on it well i have put 73-87 style ball joints in my stock upper control arm. well when i put the spindle on the castle nut goes up so far that i cotter wont even go through it, its to low. what do i need to do, do i need 73-87 upper control arms, what else do i need to change, do get this thing fixed.
Brandon
67 chevy CST
68 chevy stepside US ARMY truck
69 chevy longbed green and white Custom10
05 Honda Rancher AT with 26 inch ITP 589's
2008 Chevy crewcab vortec max 4X4 pickup
1969 Chevrolet layin frame Project Fools Gold
http://67-72chevytrucks.com/vboard/s...d.php?t=257593
brandonh is offline   Reply With Quote
Old 11-12-2005, 03:32 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: need help with suspesion swap
Not sure when you say the castlated nut goes up so far that the cotter pin will not go thru..... I have not had this problem with the upper ball joint that fits the spindle. I have had to drill a new cotter pin hole occasionally in the lower. Drill another cotter pin hole? It is close to a 1/8 hole or next size down --3/32.
dennislbrooks is offline   Reply With Quote
Old 11-12-2005, 03:43 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
You can do one of two things.
Get a taller castle nut or get a grade 8 washer, they come in thick a normal thickness. Don't put 2 washers in there just one and don't use a standard grade washer. If the cotter pin then does not lock the nut you have to find out what parts is wrong or defective.
dwcsr is offline   Reply With Quote
Old 11-14-2005, 06:43 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I use a decent 1/2 inch flat washer.
