Old 11-13-2005, 08:58 AM   #1
70GMCer
70GMCer's Avatar
Temp Sending switch ?
Does anyone know if the water temp switch on the head is the same unit if you have the light or the gauge on the dash cluster? I had changed from lights to the gauges, and the needle doesn't go above the 1st mark. Is there something wrong with the gauge, or might it be the wrong switch on the engine? Does anyone have the part number for the gauge sending unit I would need and where to buy it? Auto Zone or Advance doesn't have a clue. They don't list gauges in their parts, which I figured......
thanks, Steve
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-13-2005, 09:00 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Temp Sending switch ?
two seperate part numbers. One has a said connector, the other looks liek a nail head.
Old 11-13-2005, 09:08 AM   #3
70GMCer
70GMCer's Avatar
The one I have is a nail head.....which is that for?
1997 GMC Sierra Ext
1965 Mustang
Old 11-13-2005, 09:23 AM   #4
truckdude239
truckdude239's Avatar
the idiot light
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-13-2005, 09:39 AM   #5
sinister72
sinister72's Avatar
I have the one that looks like a nail head, and it works with my gauge cluster
72 chevy C-10 swb fleetside,402 BB.700r4,buckets,console.etc.
72 Blazer CST 350,AT, new project
1971 Chevy Nova ,355 SB blow through turbo in works.
sinister72 is offline   Reply With Quote
Old 11-13-2005, 11:09 AM   #6
68 Stepside
huh?
68 Stepside's Avatar
The nail head should be for the gauge setup. I've had 3 different gauge clusters in my truck, and 2 different temperature sending units, and at 190 degrees, my needle has always been just on the first mark.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 11-13-2005, 01:04 PM   #7
70GMCer
70GMCer's Avatar
Same here, near the 1st mark, but at times goes to 3/4 mark for a minute and then back.....That's why I was wondering if I have the right sending unit....
1997 GMC Sierra Ext
1965 Mustang
Old 11-13-2005, 01:24 PM   #8
LONGHAIR
They are deffinately different.
The sender for the gauge should be progressive...making it rise slowly.
The one for the idiot light will jump suddenly.
Why not just test it?
The sender is just a "grounding" unit. If you ground your wire to the gauge it should "peg" the gauge. The gauge sender works like a rheostat, progressively giving more ground. The idiot light just trips all at once, when it hits a pre-determined temp.
If you heat the gauge manually (gently with a propane torch or something similar) while keeping the external housing grounded, you should be able to tell which way it works. The pain factor in this is the you have to remove it for the test.
Another thing that can affect the sender is the ground itself. If you have liquid pipe-dope or excessive wraps of tape........it may not be getting enough ground to go any higher. Since you said that is goes up some and stops, this may be your only problem. If so, you still need to take it out to fix it..........might as well test it while it's out.
LONGHAIR is offline   Reply With Quote
Old 11-13-2005, 01:27 PM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Thumbs up Re: Temp Sending switch ?
The Nail Head is correct for the guage, Standard #TS-6, Borg Warner #WT-203. Hope this helps!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 11-13-2005, 01:59 PM   #10
70GMCer
70GMCer's Avatar
Thanks for the help on this and also for the part numbers......
1997 GMC Sierra Ext
1965 Mustang
