![]() Join Date: May 2004
400 kickdown
I temporarily hooked up my remote starter switch on my kickdown switch. This is what I found out when I push the button: it will kickdown at any speed below 2000rpm, and will stay in 2nd until about 2800rpm, then it will shift into 3rd. So it will not engage above 2000rpm. Is this correct???
Re: 400 kickdown
Depending on how the trans is setup ie modulator, govenor, and valve body....this could be correct. However, to tell a little more info is needed. When you tested this, trans was in Drive and you went to WOT...right?
'72 C10 lwb 454/TH400 |
Re: 400 kickdown
Trans was in Drive. I didn't go into WOT. I simply pushed the button on the switch. I have it hooked up to test the kickdown. I don't have a normal switch on the gas pedal or carb.
Re: 400 kickdown
What do you guys think????
#5 | |
Re: 400 kickdown
Hope that helps.
Re: 400 kickdown
It helps. I just wanted to make sure it was normal. Is this adjustable at all??
Re: 400 kickdown
Sure, you can adjust this within reason. But this is normally based on the upshift at WOT at a specified RPM. Once you get that set you can them slightly modify when it downshifts. Most people don't worry about part throttle upshift as this is the "passing gear" settings, not cruise. Hopefully that makes sense, if not or you have more ?? please post.
Re: 400 kickdown
Right now I have an Eaton Rear with 4.57 gears & 29" tires. At 2000 RPMs, I am only going less than 40mph. I plan on going to 3.08 gears and 26" tires. At 2000 RPM, I will be about 50mph. I would like it to engage up to 2500rpm. I should be at about 65mph then. Is this easily accomplished??
Re: 400 kickdown
You need to try it at WOT then push your button the vaccum at WOT is very diferent than at part throttle and the tranny will react very different. So to test what you want, go to WOT then push you button and see what how the tranny reacts.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Re: 400 kickdown
I don't know of a way to calculate what changes are made. I'd say make your gear/tire changes and see how it acts. It's possible that the downshift point may move to where you want. The trans looks at a number of inputs to figure out how to respond, mainly the vac from engine and output shaft speed. You'll be changing both of these, so you'll have to retest. Also, you said you received the downshift by activating the kickdown, but not at WOT. You may very well get a kickdown at 2500 or even 3000 rpm at WOT.
Re: 400 kickdown
Thanks guys, I will try it again tonight & respond back...
Re: 400 kickdown
I tried it at WOT on my way home from work yesterday. No change. I will try it again after I do the rearend and tire swap...Thanks for the help...Chris
#13 |
Re: 400 kickdown
Hey Chris,
If you take off from a stop in Drive and floor it, does the trans shift around 2800 RPM's then? If that's the case then your kickdown is working as I would expect and YES this is adjustable. You would need to modify the govenor to get a higher upshift at WOT. You can do it yourself or have a shop take a look. I purchased a B&M kit from summit for a few $$ that makes this easy and straight forward.
#14 |
Re: 400 kickdown
I will check it tonight. Which kit from B&M did you use?? A regular shift kit?? I would like the kickdown to be operational until about 2750-3000RPM. Is this possible?
#15 |
![]() Join Date: Jul 2004
Re: 400 kickdown
Assuming that is a momentary contact starter switch, to emulate normal operation, you need to hold the switch in during the duration of the WOT, and ONLY during WOT, cause thats what is is, it's designed to tell the tranny when you go to WOT, to activate it at any other time during part throttle is not what it was designed for.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#16 |
Re: 400 kickdown
I am holding it down for quite a few seconds, basically until I am satisfied that it is not going to engage. I have done this at WOT and partial throttle.
#17 |
Re: 400 kickdown
Try this - from a dead stop in drive, do not push switch, floor it and tell us at what rpms it shifts to 2nd and what rpm it hits 3rd. Then do same thing from a dead stop, hold the switch down the whole time now until it hits 3rd, floor it and tell us what rpms it shifts at then, that will help tell the rest of the story....
#18 |
Re: 400 kickdown
Greenmachine is right...I failed to mention, you should be holding the switch down, not releasing it. This will tell the whole story. Once you know that the kit I used to modify the trans was a B&M - 20248. You can search on Summit's website for BMM-20248, runs just under $30. Nice part is it comes with decent instructions to get what you want.
#19 |
Re: 400 kickdown
Do you have to drain the tranny to install and after install can you adjust it with out draining tranny again?
#20 | |
Re: 400 kickdown
#21 |
Re: 400 kickdown
Sorry it's been awhile, but anyways, in normal driving, the trans shifts from 1st-2nd from 1500-1600RPM & 2nd-3rd from 1700-1900RPM. At WOT it shifts into 2nd at about 3400-3500RPM & into 3rd at about 3500-3600RPM, this is W/O the switch being pushed at all. So, do want me to try this same test with the switch being pushed the whole time from a dead stop at WOT???
#22 | |
Re: 400 kickdown
#23 |
1968 C20 Vortec Beast
Re: 400 kickdown
I hace the factory kickdown switch that goes on the firewall if you need it. You can have it, just pay the postage. The trick will be getting the bolt on the pedal. Let me know. I can even get you pics if you need them.
Ugly or not it still kicks a**! |
#24 |
Re: 400 kickdown
When I stomp on it at WOT from a dead stop with the button pushed it shifts from 1st-2nd @4300-4500RPM & 2nd-3rd @3700-3900RPM. If this is normal, do you think that governor kit you bought will enable the kickdown to be actuated at 2000+RPM??
Stueber68, please send me pics of the switch. Right now, I have a rod-type mechanical linkage, but I will be switching to a cable-operated one shortly. |
#25 |
Re: 400 kickdown
Those numbers sound like everything is working as it should. The kit I have is primarily used to adjust the upshift point at WOT. However, when you raise the upshift point typically the max rpm that it will kickdown at raises also. Not sure if I worded that right, but the higher the upshift the higher the RPM which it will still kickdown. Becasue of this I have mine set to upshift at approx 5k which gets me the kickdown rpm I want. When I want to run up to my max rpm of 6200 I shift manually.
To answer your question about the kit getting you the numbers you want is very tough. I would say most likely you'll be fine.
