Old 11-13-2005, 03:05 PM   #1
atcavage
Heater smokes
On cold mornings (go figure), I'll turn on my heater and defroster, and after about five minutes (once it heats up), I get smoke. If I turn off the heater, smoke will gently creep out for a while. If I crank it, smoke will pour out and fill the cab until it runs out of whatever is causing it. I haven't been able to reproduce it except driving on a cold morning, and can't figure out what the problem is.
I've heard leaves rustling around in there, but I'm pretty sure I got them all out. It might be electrical, but I've experienced no electrical problems and the smoke doesn't smell like an electrical fire.
I've had no other problems, and the fan runs fine. Not a major issue, but I want to run my heater without walking into work smelling like I was just at an early morning barbeque.
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 11-13-2005, 03:11 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Heater smokes
mmmmmmmm barbeque........ droooooooooolllllllllll.
What exactly does it smell like?
Old 11-13-2005, 03:14 PM   #3
llegos
Re: Heater smokes
yea whats it closer to, beef or pork?lol
-Steve
llegos is offline   Reply With Quote
Old 11-13-2005, 03:59 PM   #4
atcavage
Re: Heater smokes
Doesn't really smell like anything. I would almost say it was dry ice. Perhaps slightly like vinyl or plastic, but not like burning wires.
Old 11-13-2005, 04:33 PM   #5
Longhorn Man
Re: Heater smokes
Your truck have A/C by chance? (or originally had a/c even?)
Old 11-13-2005, 04:47 PM   #6
atcavage
Re: Heater smokes
No a/c ever.
Air conditioning is the only requirement of my next vehicle.
Old 11-13-2005, 08:37 PM   #7
jhow66
jhow66's Avatar
Re: Heater smokes
Heater core leaking--antifreeze fog.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-13-2005, 08:55 PM   #8
68 Stepside
huh?
68 Stepside's Avatar
Re: Heater smokes
I agree with jhow. My 66 C20 did the exact same thing. Kind of a sweet smell.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 11-13-2005, 09:29 PM   #9
franko72
Franko72
franko72's Avatar
Re: Heater smokes
The only thing that has happened like this in one of my cars has been the heater core causing a mist to fog up the cab. Check your fluid level in Radiator
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 11-13-2005, 10:11 PM   #10
atcavage
Re: Heater smokes
The mist/fog from the antifreeze is probably it. Didn't really smell though. I'll pop the hood and Czech out my fluid levels.
Old 11-13-2005, 10:12 PM   #11
Longhorn Man
Re: Heater smokes
Does it actually defog the glass...or cause more fog?
Old 11-14-2005, 11:13 AM   #12
atcavage
Re: Heater smokes
Just creates more fog, until a few minutes later it mysteriously stops.
Old 11-14-2005, 01:14 PM   #13
truckdude239
truckdude239's Avatar
Re: Heater smokes
sounds like an leaking heater core to me my 87 f-150 beater was dping the same i just by passed the core but i think for 17 buxs i'm going to install an new one. but i'd change the fuild when i change the core if i was u. just my$0.02
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-14-2005, 04:32 PM   #14
Longhorn Man
Re: Heater smokes
well, some liquid is getting on thew heqater core, this is certian.
The part I find interesting, is that it doesn't get worse with higher eng temp/higher pressure.
Seems odd.
Plan on pulling the hood hinge off and dropping the fenderwell and looking at what is going on. Heater cores are cheap, and the fit is close... not dead on, but close.
Old 11-14-2005, 06:51 PM   #15
Z28Owner
Z28Owner's Avatar
Re: Heater smokes
My first 1970 truck did that too, caught on fire and burnt down in my driveway. Might want to keep it off till you figure it out. I still dont know what happened, I am thinking it was the blower motor and sparks set something ablaze.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 11-15-2005, 12:26 AM   #16
atcavage
Re: Heater smokes
Thanks. Guess I'll have a 'fun' weekend ahead of me. Why is it that none of the things you plan to replace break, and instead is the stuff you actually need? At this rate, the only original thing on my truck will be the body and chassis.
Cop: And what exactly are you doing at 3AM with both windows down and all that smoke coming out of your windows?
