Old 11-13-2005, 03:41 PM   #1
69 air cab
How to remove and install fender emblems??
I have an 84 Silverado going in for paint. How do you remove the fender emblems "Silverado10". Also, who should I buy new ones from and are they stick on or do you have to remover the fender to install?
69 air cab is offline   Reply With Quote
Old 11-13-2005, 05:52 PM   #2
ureckme
ureckmefixit2@cox.net
Re: How to remove and install fender emblems??
Bad news, a lot not all have nuts on the back so it must have been put on before the fender was put on. You can get a thin putty knife and a hammer and try to cut thru the studs holding it on. But first check and see if its got nuts on the back. Matt
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 11-13-2005, 07:30 PM   #3
69 air cab
I hate to hear I have to take the fender off. If I knew how the news ones installed I could just break it off.
Old 11-13-2005, 10:36 PM   #4
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
They have plastic studs that go through the fender. They use speednuts to attach. You can reach through the hole in the fender above the inner fender to get them off.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
