Distributor Question
I just replaced my used HEI with a brand new one. Thought it would be a simple swap - WRONG!!! I thought I lined it up the same as the old one, but it pops and spits fire thru the carb. Please settle a shop disagreement. If you are look down onto the top of the distributor is the 1-8-4-3-6-5-7-2 firing order in a clockwise, or counterclockwise pattern with regard to the plug wire placement?
Yes, this do go into the hall of fame of stupid, too many beers, mechanical questions. Thanks for your help. |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
clockwise....
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
clockwise
Used to have a truck
18436572 and its clockwise as you look down on the top of the cap. Doesnt matter where the placement of "1" is. bring the motor up to 10 degrees advanced on # 1 TDC and line up the rotor with one of the posts on the distributor . assign that as #1 then work your way around. That'll get you in ballpark to start the thing and time it..
No truck :-( |
