Old 11-13-2005, 11:01 PM   #1
kd71chevy
71 Chevy - Driveshaft
I have a 71 Chevy LWB we are wanting to replace the 3spd with a 700r4 and I'm wondering if anyone out there has found a driveshaft that works with this without modification, or if I'm just better off having my current shaft shortened.
If I have to shorten it, does anyone know by how much?
kd71chevy is offline   Reply With Quote
Old 11-13-2005, 11:18 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 71 Chevy - Driveshaft
Welcome to the board
I can't answer your Q...but I'm willing to bet some one can.
Is this a small block truck? Is it mounted in the correct V-8 position with the V-8 towers?
Old 11-14-2005, 12:57 PM   #3
kd71chevy
The truck is an original sb v-8 with a 3spd column shift transmission and a 2pc driveshaft.
I am wanting to go back with the 350 sbc in the original location, with a 700r4 transmission.
My key question is if there is a ready fit driveshaft off of some other vehicle that I can use, or do I have to get my shaft cut.
If I have to get it cut, does anyone know how much?
Old 11-15-2005, 10:56 AM   #4
71 gmc sled
that's a good question. I have the same truck n am looking 4 the same answer n i have a th 350 trans w/ a 350.
71 gmc sled is offline   Reply With Quote
Old 11-15-2005, 04:29 PM   #5
Longhorn Man
If not mistaken, your 3 speed is the same length and takes the same yoke as a TH350.
Still not able to answer your Q.. but TH350 to 700R4 has been done a billion times on here, and THAT could be answered.
Old 11-15-2005, 04:46 PM   #6
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
When I get home I'll measure my driveshaft. I'm pretty sure its a 57". Don't know what its off of, one of my buddies gave it to me when I did the swap. It is the same spline as a TH350, though, so thats easy. More tonight. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 11-15-2005, 06:48 PM   #7
red71cheyenne
Back in the sticks
Ok, I was a little off. Mine is 68" from center of U-joint to U-joint. Like I said, I don't know what it came off of, but its a good fit. Only issue I have, is when I hit a big bump, the shaft rubs the cross member it runs through on the frame. That might just be a 30 year old shock thing though. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
