Old 11-14-2005, 01:34 AM   #1
Eyegore
What Hump?
Eyegore's Avatar
Unhappy Transmission Help
My son was driving his 78, 3/4 camper today and his transmission would not shift from first to any other gear, works ok in reverse and first but not second or third, also will not manually shift into those gears either. This is a 78 with I believe at th400. Was working great no trouble, trans fluid does not smell burnt, any ideas?
Thanks ahead of time.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 11-14-2005, 02:34 AM   #2
Russell
Professional Grade
Russell's Avatar
Re: Transmission Help
Check the vaccum modulator, the line may have fallen off, or the modulator may have failed all together.
The TH400 will not shift out of 1st gear until the govenor tells it to at a very high rpm if the modulator isn't working properly, and it will be a very hard shift when it does.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 11-14-2005, 09:49 AM   #3
Eyegore
What Hump?
Eyegore's Avatar
Thanks Russel, will check it this evening when I get home
Lil red 86 c-10
99 Sub
