3 parts need identification + 1 question
Hey there folks,
#1.) My memory is challenged and I cant remember what the silver thing is. Can you help? ![]() #2.) Where can I buy new hose clamps like this? ![]() #3.) Where can I get a new connector plug for engine temp sensor like this? ![]() #4.) Which side of a big block gets the temperature sensor? Driver? ![]() Thanks ahead of time, and if you cant ansewe all of them please send TTT.
Chuck 1972 C-20 Longhorn 402 BB .030" over (409?), curved HEI, RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit 1999 K1500 Suburban (old style) 5.7L Vortec 4L60E "No matter where you go, ........ there you are" Last edited by 72 longhorn BB; 11-14-2005 at 07:47 PM. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: 3 parts need identification + 1 question
#1 is a spark plug wire heat shield... can't help on the others but here's a bump..
![]() Join Date: Sep 2003
#1
![]() #2 and #3 you can buy through a supplier that sells camaro or chevelle parts. Classic industries has them as well. You will also need to get the heat insulation for the green temp wire. This usually comes in a repair kit. #4 driver |
Thanks, I'll check out classic ind. I can't imagine where the SB spark plugh wire heat shield came from though.
Thanks again.
Chuck 1972 C-20 Longhorn 402 BB .030" over (409?), curved HEI, RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit 1999 K1500 Suburban (old style) 5.7L Vortec 4L60E "No matter where you go, ........ there you are" |
