11-14-2005, 08:32 PM | #1 |
Rear light wiring
ok i have pics for better explanation. i have no side markers so i am missing 2 brown wires which is ok, and i have a 4 way junction of the other brown wires. 1 goes to the license plate, one to the left tail, one to the right and the 4th comes from the plug. do i need a 5th brown wire to ground the harness? currently i have no ground and thought that would be the place to put it if needed.
here's what i have now is this what it should look like? thanks |
11-14-2005, 08:41 PM | #2 |
its all about the +6 inches
Re: Rear light wiring
If you ground the brown wire, you will blow the fuse.
The lights are grounded through the metal bucket.... or what ever you want to call the lamp assembly. |
11-14-2005, 09:00 PM | #3 |
so i'm good as is in the 1st picture right? thank god you answered 1st, always the most informative.
11-14-2005, 09:37 PM | #4 |
that is correct, pic #1.
11-14-2005, 09:40 PM | #5 |
thanks a bunch!
11-14-2005, 09:48 PM | #6 |
the side markers are ground with a wire from the lightsocket to the frame i just redid mine not 2 long ago ( u got to pull the lence and palstic bucket out) but the side marker i just fed off the park light wire that went to the tail lights
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 11-14-2005 at 10:09 PM. |
11-14-2005, 10:00 PM | #7 |
Watch out for your cornhole !
The reason the side markers carry a separate ground wire is that they are plastic. The tailight and backup light buckets are steel, they are self grounding like Andy said.
11-14-2005, 10:18 PM | #8 |
i shaved my side markers, so there's no hole for them to go now. thanks for that info.
