When Im driving I can turn my wheel to side to side 5-10inches or so without the truck responding what causes this to happen. Is it an easy fix. Balance? Im clueless on the whole thing.
You can have someone look at the steering components while you turn the steering wheel back and forth, (you don't need to run the engine to check slack). Typical items where slop is likely include tie rod ends, drag link, rag joint and steering box but everything should be inspected.
Jim |
Re: Loose steering wheel HELP?
have someone turn the steering wheel and keep an eye at the bottom of the steering gearbox on the frame. if they move the steering wheel, and you see no movement under the gearbox, get the gearbox rebuilt.
How much will it cost to get the gear box rebuilt?
hundreds, sorry man. i'm looking for a new seal for mine right now because it's leaking, maybe yours needs more fluid.
its all about the +6 inches
do you have manual steering? They seem to be 10 times sloppier than power assist.
if so, may be a good time to upgrade? |
![]() Join Date: Sep 2005
i have manual steering and just installed an new gear box heres the link http://www.partsamerica.com/ProductL...ering+Gear+Box
148 buxs -250 buxs for an rebuilt one
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'm radical here, but I'd use that handy adjusting screw that is on there to attempt to remove the slack before I blindly replaced the gearbox.
Loosen lock nut, tighten screw some, tighten locknut. Price? Free.
Although I would also try that too.... there is no way that adjuster will get rid of 5 inches of play.
