Old 11-15-2005, 12:58 AM   #1
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
I need of a picture and help...
I am looking for a picture of a front sway bar on a truck, my 74 did not have one, but I want an idea of how it bolts to the frame/lower arms, thanks..also does anyone know the best place to p/u a rear sway bar kit for 73-80/87 thanks..
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 11-15-2005, 01:40 AM   #2
ureckme
ureckmefixit2@cox.net
Re: I need of a picture and help...
Mine didn't have one on it from the factory. There is 2 brakets that go on the frame that you might need to get. If your truck is lowered you dont need them. Sorry dont have pic. Matt
That's U RECK ME FIX it 2
74 Chevy Short Bed
355ci Sportsman II 64cc Angle Plug
Crower Custom Grind .462in .486ex
Dyno Test 422hp @ 5600
And it's got a Holley
3.73 Gears
12 Bolt 3.73 w/Posi
700R4 Going In
I'm a Body Man So There!
That's why it's not painted
ureckme is offline   Reply With Quote
Old 11-15-2005, 01:42 AM   #3
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I don't have a pic but the sway bar mounts to the arm on the lower side with a U bracket and 2 bolts on either arm. Then it mounts the same way in the frame with some brackets that you can get at the GM dealer. It's an easy upgrade wince the holes are alreads there. You can pick up sway bars an junkyards. Looks for 2wd 3/4 or 1 on for the heavier sizes. You want at least a 1 1/8" diameter size.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 11-15-2005, 02:00 AM   #4
AspecialZ
AspecialZ's Avatar
thank you both for the info, I have a 1ton one, but in my 74 frame it has 1 bolt hole, not 2 for the bracket to mount too.
Old 11-15-2005, 07:41 AM   #5
bigblock73
yeller
bigblock73's Avatar
I have John's article linked to the 73-87 garage section, hopefully it will help you out.
http://www.delbridge.net/sway
bigblock73 is offline   Reply With Quote
Old 11-15-2005, 08:25 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Here you go....
These pictures came out of an article I wrote on front swaybars. There are more pictures too. It's here....http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
Old 11-15-2005, 08:37 AM   #7
bigblock73
yeller
bigblock73's Avatar
Awesome article TX!!!
Old 11-15-2005, 12:37 PM   #8
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: I need of a picture and help...
Wrong-O,
A friend of mine told me the same thing and i tried every way you can think of to make that bar fit with out using the brackets and it's a no go situation.
And if you can get pic's id like to see it.
Those ECE frame brackets that Tx is using look good i think i can get another set of factory frame brackets and modify them like the ECE ones.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 11-19-2005, 01:20 AM   #9
AspecialZ
AspecialZ's Avatar
i thank you all for the input, those factory drop down brackets do not exist on mine, but the second pic may work. THANKS!!
Old 11-19-2005, 01:38 AM   #10
Slonaker
Insert Witty Text Here
Slonaker's Avatar
The brackets are available at the dealer, and they are not expensive. My truck did not come with them. They are riveted on if your truck came with them from the factory. It was much easier to buy them than to chisel them off a junkyard truck. If you have a lot of drop, the ECE ones are probably the way to go.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-19-2005, 04:52 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by 87 STEPPER
Wrong-O,
I don't have pics, but I do know that forum member Scoti has his front sway bar bolted directly to the frame. Maybe he can tell you how it's done.
For the price of the ECE lowered brackets there is no point in buying stock brackets, or building your won. They are too cheap, and the fab work is already done....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
