Old 07-10-2002, 06:51 AM   #1
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
Argh, did I mess my tranny cooler up?
When I installed my tranny cooler last night, I decided to run it before the radiator on some advice I had gotten. Now the more that I think about it, the more I think that I messed it up - how can my tranny cooler be doing much if the cooled tranny fluid just goes through the radiator and heats back up?
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 07-10-2002, 07:25 AM   #2
RipMeyer
RipMeyer's Avatar
Your correct, however I dont think you messed it up in any way. Just reroute it after the radiator or eliminate the radiator portion alltogeather.
RipMeyer is offline   Reply With Quote
Old 07-10-2002, 07:59 AM   #3
Patrick Sullivan
Hmm yes, but I already cut one of the lines and I'm out of hose and barb fittings.
Oh well.
Old 07-10-2002, 08:09 AM   #4
racedvl
racedvl's Avatar
I did mine rad. first then cooler. Like you said, your gonna just heat it back up once it hits the rad..
racedvl is offline   Reply With Quote
Old 07-10-2002, 08:31 AM   #5
Patrick Sullivan
Yeah..
I've got it switched around now, didn't think the hose I had would stretch far enough.. but it did.
Looks like a definate hack job now, but it'll work I suppose.. just need to wait until the shop opens so I can get some more hose clamps.
Old 07-10-2002, 09:13 AM   #6
mrein3
mrein3's Avatar
Be careful in the winter. In the winter you want your fluid warmed up some. It may get TOO cold if you go radiator then external cooler.
I have my cooler BEFORE the radiator. I also installed a temp gauge. Not towing my tranny runs a consistant 150 degrees. Towing my boat it runs 185 going down the slab and stays under 200 in stop-and-go traffic. Perfect.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-10-2002, 09:30 AM   #7
da-burb
"Ochre Ogre"
da-burb's Avatar
Us northern guys need to run it through the cooler first and the radiator last just to warm the fluid back up to normal operating temps. I have been told running your tranny cold can be just as bad for it as running it hot .
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 07-10-2002, 09:44 AM   #8
Patrick Sullivan
Yea, that's what I had heard.
Oh well, it's reversed now.. took it for a drive again, nothing seems to be leaking. The hoses are kinda stretched tight, but hey..
I suppose it never gets under 32 here anyway.. being next to the ocean and all.
Old 07-10-2002, 09:58 AM   #9
Low69CST
i was going to run mine the radiator then to the cooler infront of the radiator. Anyone use braided line for a tranny cooler?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-10-2002, 12:15 PM   #10
ThreeQuarter
ThreeQuarter's Avatar
I thought the first method was the correct one. Tranny fluid is designed to have certain properties at a certain temp, and that temp is set by the radiator. If it's cooler than that, the tranny has to deal with fluid that's too thick, etc. You want it to have a specific temp, not just have it as cold as you can get it. By running it through the radiator last, it will most always be the same temp no matter the weather.
If you run already-cooled tranny fluid into the rad, then you have not only taken the tranny fluid heat load off of the rad, but you'll actually cool the radiator a bit (we're splitting hairs here) by sinking heat back into the tranny fluid.
I believe it's not about how cold you can get it, but instead how close to the correct temp at which it's designed to run.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 07-10-2002, 12:30 PM   #11
JJ
Lurking Member
GMCBLU got it right, the object is not to run the transmission at a low temperature. The viscosity of the oil is set for certain parameters, the operating temperature has to be in a given range to allow the lubricating properties, as well as the cooling function. There is a specific reason why the systems are engineered to go through the radiator. You will shorten the life of the tranny if you change it, but then again my dad ran his for almost 180,000 miles before it failed, you'll never convince him that it was incorrect.
JJ
72 GMC 1500 350 4 Speed, stone stock baby!!!!!
72 GMC K-2500 350TPI 700R4
For those who fought for it, Freedom has a flavor the protected will never know.
JJ is offline   Reply With Quote
Old 07-10-2002, 01:17 PM   #12
68 with 350 TPI
68 with 350 TPI's Avatar
I dont think you will have to worry about over cooling in except maby in the dead cold of wenter.
Even then you can put a sheild in frnt of it like the big rigs do to keep some heat in if you wanted to.
Heat is the # one killer of the auto trans.
GM has put tranny coolers/power steering coolers on a lot of their work big work trucks without problems for years.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
