11-15-2005, 12:00 PM | #1 |
Casting #'s
Still looking for an engine. Can someone look up these numbers for me?
Block- 3914678 Heads- 3782461 Thanks in advance. John |
11-15-2005, 12:13 PM | #2 |
Re: Casting #'s
As per Mor Tec, 3914678= 68, 302 327 350
3782461= 64-66 camel hump, 160/62cc ports, 62cc chambers. Are these numbers what you have or what you are looking for?
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
11-15-2005, 12:18 PM | #3 |
TOTY 2006
Re: Casting #'s
That engine number was used on three different engines.
Year number size hp Low High carb vehical 1968 3914678 302 290 290 2/4 Camaro, Z-28 1968 3914678 327 210 350 2 car & truck 1968 3914678 350 295 295 2 Camaro/ChevyII The heads are 1962-67 3782461 327 1.94 1.5 So if you got these numbers off an complete engine with heads, chances are the engine is the 327. This info is from http://www.nastyz28.com |
11-15-2005, 04:09 PM | #4 |
Re: Casting #'s
Thanks Woodridge and John. It's for an engine I am looking at. Seller claims its a 327 out of a Camaro. It sounded right but I just wanted to make sure.
John, if I'm reading that website correctly, it says the block is rated up to 350HP right? |
11-15-2005, 05:39 PM | #5 |
Re: Casting #'s
That's the same block that 's in my truck (Stock 327, large journal 2 bolt mains)
It'd be interesting to run the numbers on the crank. That could be a 302 if its a Camero block.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
11-15-2005, 09:07 PM | #6 |
TOTY 2006
Re: Casting #'s
If it is the factory camaro engine, it was rated at 295, if it came out of chevy car or truck, it was anywhere from 210 up to 350.
11-15-2005, 10:00 PM | #7 |
Re: Casting #'s
I'm considering dropping a 327 in my truck (it currently has a 283) since that is what it originally came with. And if I can't find a truck motor, I'm gonna try and find something close.
