Old 11-15-2005, 01:49 PM   #1
72longbed
72longbed's Avatar
Question 4 Wheel Disks W/Factory Master Cylinder??
For those of you who have converted your 71/72 truck to 4 wheel disk brakes; can we still use the factory power brake master cylinder? Mine is the 3/4 ton Hydro-Boost master cylinder with a later 73up proportioning valve on it, has the large diameter vacuum booster on it.
Just want to make sure I don't kill myself when I go out on the 'maiden' voyage with the new truck.
Thanks for the info,
72longbed
72longbed is offline   Reply With Quote
Old 11-15-2005, 01:55 PM   #2
truckdude239
truckdude239's Avatar
Re: 4 Wheel Disks W/Factory Master Cylinder??
u need to find an mc thats desized for disc brakes disc brakes take more pressure then drums
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-15-2005, 02:06 PM   #3
FormerMember
I've run the stock MC with the correct disk/disk proportioning valve.
FormerMember is offline   Reply With Quote
Old 11-15-2005, 02:12 PM   #4
75stepside
*Proud Member*
75stepside's Avatar
I agree... i just finished my 4 year restoration in July and put disc on the rear of my '75 project. The master cylinder and brake booster were on the cab i used, from an '84. i hooked up my rear disc with the stock proportioning valve and had bad results... not enough pressure to the rear... then i put a new disc/disc p valve in the rear... everything works great... put on my first 300 miles this summer - working great!
http://www.inlinetube.com/
http://www.inlinetube.com/Prop%20Valves/PR-101.htm
75stepside is offline   Reply With Quote
Old 11-15-2005, 02:19 PM   #5
FormerMember
Yep. AFAIK, the bore and stroke of the 1/2 ton MC is the same as many of the disk/disk MC's.
Just that our prop valve has a check valve for the rear drum brake circuit.
Old 11-15-2005, 05:47 PM   #6
RainFade
RainFade's Avatar
72longbed
Working fine on my 71 just keep an eye on your fluid as the pads wear as the drum resevior is pretty tiny!
I did use the correct combo valve for rear disc and ended up dialing the rear pressure down a bit to keep her from locking when empty on wet roads.
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes.
My lame K20 page
My lame Eaton disc brake page
RainFade is offline   Reply With Quote
Old 11-16-2005, 12:21 PM   #7
72longbed
72longbed's Avatar
Thumbs up Re: 4 Wheel Disks W/Factory Master Cylinder??
Thanks for the info everybody! Looks like I need to get that Disk/Disk prop. valve from Inline Tube, just wish I could find one a lot cheaper!
If you all know of the same valve for less $$$, let me know.
Thanks,
72longbed
Old 11-16-2005, 12:38 PM   #8
dennislbrooks
dennislbrooks's Avatar
I used a 76 corvette mc with good results with a wildwood adjustable prop valve.
dennislbrooks is offline   Reply With Quote
Old 11-16-2005, 01:26 PM   #9
raggedjim
raggedjim's Avatar
All you gotta do is ask!
http://www.classicperform.com/Store/...ruck/PVKS2.htm
Same one I have.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 11-16-2005, 01:27 PM   #10
FormerMember
Bought mine on Ebay. 22.00.
Old 11-16-2005, 08:47 PM   #11
Oborny71
Oborny71's Avatar
also take out the check valve spring in the mater cylinder if converting from drums to discs, both check valves if using front and rear discs. to do this, screw a screw into the flare fitting(s) in the master cylinder, then pull them out. after you get that, out will come the spring, then replace the fitting. this is to keep the pads on drums from backing away from the drums, but you don't want that with discs. as mentioned, use a different proportioning valve too.
67 Chevy SWB - goal of a 1,000 hp weekend cruiser
Oborny71 is offline   Reply With Quote
Old 11-19-2005, 10:30 AM   #12
72longbed
72longbed's Avatar
grendel,
thats a good price! What part did you look for on E-Bay for this type application? Was it a private seller or a company?
Thanks to all for the valuable info,
72longbed
Old 08-20-2006, 03:51 PM   #13
nate68
i think i used the 76 'vette master cylinder but i can't find my receipt or part number. i tried looking it up online at kragen and autozone and the 76 was giving me weird results.
also using the wilwood adjustable proportioning valve
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 08-20-2006, 03:54 PM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Did any of you check the line pressure at the rear with the wrong master cylinder? I can't remember the specs, but disks require much higher pressure.
Old 08-20-2006, 03:58 PM   #15
nate68
oh yeah and my master cylinder needs to be replaced and i dont wanna spend a million dollars on a billet one
what kind of price range am i looking at?
Old 08-20-2006, 05:49 PM   #16
ratrod67
ratrod67's Avatar
I have a master from a 74 Corvette from O'Reillys($46) and a Master Power valve($89) in mine.
ratrod67 is offline   Reply With Quote
Old 08-20-2006, 06:28 PM   #17
drink2mny
drink2mny's Avatar
I wanted to give my 2 cents here about the rear disc brakes..
I personnally have installed several rear disc brakes kit ranging from cars to trucks.. 1/2tons to 2 1/2 tons.. I have rear disc on my '72 3/4 ton, had rear disc on my '86 1/2 ton blazer with 36" swampers an 14 bolt rear(sold her)..
Put rear disc on a drag car '70 elkie..
I have never , i mean never need to change out a MC to a disc/disc proportioning..
As you read the post above not even all of you have done the same thing, some still needed an adjustable valve to fix thier brakes to their liking..
We as a company don't offer it because 99% of the time our kits never have an issue..
If someone bought one it would be to there preference to change it out if they thought it needed to be done..
We had 1 customer basically threaten us because we did not tell our customers that they needed a disc/disc valve.. He didn't like the way our kit felt.. his pedal had a different feel to it... well after he *****ed at us and called several "PRO" brake folks.. he bout a disc/disc valve.. guess what.....No difference
He then wanted us to refund him because the kit didn't work... We tried to work with him. offered another kit in return..But he said no..
He went to another reputable rear disc brake kit seller... Guess what... the same....even that company does what we do... not offer a disc/disc valve.. they are almost 100% not needed for our applications...
Everyone has there own choices as to what they are going to do..
I just wanted to let you know....I have never had a problem and neither has any of our customers....
I guess that was more than 2 cents...
Support The Board
drink2mny is offline   Reply With Quote
Old 08-20-2006, 09:26 PM   #18
Shane
Shane's Avatar
Will the 'Vette master cylinders bolt right up to "our" boosters? How about the brake lines ... are the fittings and everything the same?
Basically what I am asking is: Can a guy pull off the stock MC and bolt the 'Vette mc with no mods?
Shane is offline   Reply With Quote
Old 08-21-2006, 12:45 PM   #19
Shane
Shane's Avatar
TTT - curious about the Corvette MC bolting up to a stock booster.
Old 08-26-2006, 08:38 PM   #20
nate68
yes the vette master cylinder bolts right up (c'mon it's GM, everything interchanges)
i just put a new one on and bled the brakes today.
Old 08-26-2006, 09:56 PM   #21
Mudder
Mudder's Avatar
My old stepside had drums/drums with a booster. When we put the body on the 77 chassis we used the same 67 set up. A few years later I went to rear disks and kept the same just to see how things worked. They have been on there since about 1997 with no problems. I keep an eye on them, but they work great.
Mudder is offline   Reply With Quote
Old 08-26-2006, 11:46 PM   #22
truckdude239
wow puled this one from almost in the grave
David fuller
2000 Tahoe 5.3l 378
Old 08-27-2006, 07:37 AM   #23
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Subscribing to this thread, so I will have this info later, thanks guys
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
