dash without dash pad??
after finishing up my interior, im down to the last part. my question is, is there any ways to make the dash look good with out the dash pad, of course my original is toast, and i just really dont like the looks of them. if any one has any comments or picts please help me
Where's my beer?
Re: dash without dash pad??
Board member XXL should have a lot to say 'bout this issue, I could, but I don't want to intrude....................
I put fiberglass cloth behind the slots that are exposed once you remove the cover and then used some bondo hair and glassed them in. Finish with some good glaze compound prime and paint. I like it, very clean. Out atv work so can't send any pic's right now. Steve
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2. |
now when using the fiberglass cloth do u use it with the fiberglass resin or what do u use it with?
Any pics on this one??
67 is sold
There is a member with some good pics of a filled dash in progress, is it XXL?
I like that look. It takes some work, but sets it apart from the others out there ![]() |
I drove mine for a year without a pad. Holes and all. It actually didnt look too shabby.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
http://67-72chevytrucks.com/vboard/s...d.php?t=177577
I'm going to weld the holes and paint the whole truck inside then outside.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD Last edited by 67chevemall; 07-09-2010 at 02:27 PM. |
You have to use the resin, but be sure to clean and rough up the surface first. This backing gives support for the filler putty so it won't crack or pop out. I didn't have a MIG at the time that I did this, if I were to weld I would get a piece of copper rod that would fit behind the cut out that you can hold and take short burst and fill it. The copper works as a dam and gives a better hole fill, used to use a piece of electrical Buss bar to fill holes on beds. Just for clarity the copper does not flow or braze it is just a dam, but if you don't control your heat you can melt dirt. I will be home in 2 weeks and will try to get some pics. steve
