Leveling my truck
IT seems that ever since I installed my Brothers' Trucks springs, my truck seems to lean to the drivers' side more. I have at most 5k miles and probably 4 years on the springs. Before, I had the front coils cut and the rears heated evenly, and the truck seemed decently level. It's really starting to bug me. I know for a fact this truck was never in a major accident...just fender benders and such(it's a 70 C-10 btw). I installed new poly cab mounts and ended up shimming the drivers side slightly to at least line up the body lines on the cab with those on the bed- the cab use to sag more on drivers side. So now, the truck is about 1/2" to 1" lower on the driver side than the passenger side, but the cab is finally even with the bed. I was thinking it's either the frame or suspension. Any ideas what to check?? Appreciate it
71 Cheyenne 95 Civic- J32A2 V6 swap 01 MDX 04 VFR800 |
Re: Leveling my truck
Its a chevy truck thing. When they are lowered one side is a little lower. Even the s-10 blazers are like that.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
Mine was like that mostly in front about 3/4 inch lower on driver. Used two of those cheap twist in coil spring spacers work like a charm level all the way around now.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
member #16
![]() Join Date: Dec 1999
Mine did the same thing so I put a shim on one side between the trailing arm and axle. Leveled right out. The trailing arm is inboard about half way from outside to center, so mine was 3/4 " off and a 3/8" shim corrected it. Hope this helps. john
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Dork For Days
I just installed 1.5" lowering shackles on the rear of my C20 (w/leaf springs) and the driver's side is now 1" higher than the psgr side. Go figure.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status! ![]() 1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60' 2007 Dodge Charger SRT-8 2008 Cadillac CTS All-American garage, baby! |
Thanks for the help guys. I am going to slap in some lowering blocks in the rear to get me down a little further. I have a friend who works at a steel mill, so maybe I'll have him make some custom blocks that are different sizes, hoping to off set my unevenness...and for the fronts, maybe hack a section of coil out. I love the way my driver side sits, but when looking at the passenger side, it's like a different truck! Thanks for the help everyone.
