Are the bed mounts different...
if you have wood or steel?
What is factory? The bolts right through the bed floor and through the frame where you can see the bolt heads? Are the bolt heads hidden on wood beds? If so what is the difference? ![]() ![]() ![]() ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Fabricate till you "puke"
Re: Are the bed mounts different...
The bed bolts go right through the top on either wood or steel floors, the difference is that the steel floors have a 3" tall cross sill, & they are welded to the bottom of the bed floor, whereas the wood floors have a shorter cross sill (roughly 2 1/4"+ 3/4" wood to make up the height difference. I built a steel floor for my longhorn,& used 2x3x1/8 wall rectangle tubing for the cross braces.......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
right through on both.....Thanks. Man mine came with 6 hidden bolts
And the two at the very back are insane custom bolts with thread on both ends?? I finally got them back on last night so I'll just keep it that way 4 now. thanks again now it's fuel cell and carb time..... almost ready for the snow..dang it Only 4 months behind schedule.
