Old 11-16-2005, 03:07 PM   #1
chevybill
chevybill's Avatar
Question Electronic fuel pump and water pump suggestions
I am requesting some fuel pump suggestions for my vortec engine going in my 70 c 10. The engine is stock other than a MSD ready to run ignition and edelbrock carb and intake, probably going to have headers.
I need a basic electronic fuel pump, I do not want to run a return line unless absolutley necessary.
Will i run a long water pump with this engine? - it still has the factory timing cover.
Thanks for all the help
chevybill
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 11-16-2005, 03:47 PM   #2
MrC1
Dork For Days
MrC1's Avatar
Re: Electronic fuel pump and water pump suggestions
You have the right idea by not needing a monster pump. Just stay away from the Holley red or blue pumps. They're very noisy and don't have the best reputation. Holley's new pump (not sure what it's called) is more than you need, but it sounds like a nice redesign that should be much quieter.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 11-16-2005, 07:23 PM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
grant fuel pump and get a water pump for jegs i got a jegs pump alum it works nice
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 11-16-2005, 10:00 PM   #4
chevybill
chevybill's Avatar
any one have some part numbers?
do i need a long water pump for the vortec factory timing cover?
thanks for the replies.
Old 11-17-2005, 09:30 AM   #5
chevybill
chevybill's Avatar
i could use some suggestions, if anyone has some on a fuel pump and water pump.
Old 11-17-2005, 07:47 PM   #6
chevybill
chevybill's Avatar
chevybill to the board, anybody there?
Old 11-17-2005, 10:54 PM   #7
Fatback
Fatback's Avatar
ChevyBill, I am using a Purolator fuel pump:
http://www.midwayautosupply.com/deta...ption.asp?2807
Also Im using a long pump. I also used the 6cyl mounts, using no shroud.......so far no overheating issues.
The only thing about the pump....I have it mounted close to the stock location, which I dont think is advised. And it is loud...sometimes louder than the engine. I also run a 600 Holley and a "cheapo" dial type pressue regulator set at 3.5 lb. The Purolator pump puts out a 6-7 lb.
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
Fatback is offline   Reply With Quote
Old 11-18-2005, 09:07 AM   #8
chevybill
chevybill's Avatar
thanks, fatback i appreciate your response.
Old 11-18-2005, 01:43 PM   #9
Fatback
Fatback's Avatar
You may not need the regulator...I was having flooding problems, and a friend told me too much fuel pressure would cause needle and seat problems. After replacing needles and seats, and using the regulator, the problem has gone away.
Also Im not running a return line.
BTW did you get the distributor dropped in yet? Keep us posted.
70 C/10 LWB
69 Cougar
68 Mustang
68 GMC 4X4 SWB
Old 11-18-2005, 10:36 PM   #10
chevybill
chevybill's Avatar
no dizzy dropped in yet, i am taking my bed next week for sandblasting ( only bed floor to be blasted)and then all the body work will be finalized. i am also going to a local yard to try and find a hydraulic clutch pedal assembly to connect the nv 3500 tranny.
i have not completely given up on my april 2006 deadline yet.
Old 11-20-2005, 09:52 PM   #11
chevybill
chevybill's Avatar
really could use some part numbers here if anyone has suggestions thanks
Old 11-20-2005, 11:39 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
place the punp back by the tank, it'll live longer.
As for the water punp... you'll need one to work with what ever brackets you are going to use.
If you go with the stock (for the engein) serp set up, then the pump for a 94 or what ever vortec 350 will do.
If you are going to use the stock 69 - 72 brackets, (make sure you CAN...there is a hole missing on these heads) then you'll want a short pump.
Brackets from after 72 truck (after 69 car) then you'll need the long pump.
