Old 07-10-2002, 12:18 PM   #1
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
Fan how hard should it blow?
I was running my air conditioning today in my 71 Super and it just doesn't seem to blow very hard. Its a stock unit and the air is very cold. If you put the fan switch on high ( all the way down ) it won't blow at all. I run the air more just to run it than I do
because of heat ( Ontario,NY doesn't get that hot ) Just wondering if this normal or is the fan switch bad? I know it is'nt going to freeze me out of the truck but I would like it to blow alittle harder. I had a 69 short step w/a 250 straight 6 in it, my father bought new in 69 and it had factory air it was the only straight 6 I've ever seen with factory air it had 3 on the tree no power steering or brakes just air. Sorry to ramble just a slow day at work.
WHYBYNU is offline   Reply With Quote
Old 07-10-2002, 01:17 PM   #2
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
Sounds like your high speed fan relay isn't working. It's located on the ac housing below and behind the glove box. Put the fan switch on high and take a screwdriver handle and tap on the relay. If it runs, then the contacts on the relay are burned and you'll need to replace it. These are available at most auto parts stores. Hope this helps.
Old Dave is offline   Reply With Quote
Old 07-10-2002, 01:26 PM   #3
jku72
good idea, another possibility is the switch itself, in my expirience, the switch in the dash lasts about 2 seasons.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 07-10-2002, 01:52 PM   #4
WHYBYNU
WHYBYNU's Avatar
Thanks guys I'll check both of them out and let you know what I find.
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
Old 07-10-2002, 06:05 PM   #5
Project1970
14.1 @ 96MPH
Project1970's Avatar
Mine's been eating switches every few months lately, and the wiring gets too hot for comfort on high so I have that disconnected...but I'm gonna buy a new blower motor soon and see if that helps. The one in there is a 10 year old crap rebuilt one...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 07-10-2002, 07:50 PM   #6
jhow66
jhow66's Avatar
Fan
Check the large red wire at fuse panel. It plugs in to a socket labled ing. This wire supplies current to the relay on AC box beside glove box. With switch on you should have current to relay at the red wire. (with blower switch on high it closes a set of contacts sending 12 volts to fan motor).If no current at relay trace wire back to fuse panel. You probley will find a loose connection somewhere that has gotten hot enough to make a bad connection. ( Fixed a 71 this past week that had the exact problem you have--it had the above problem). Hope this helps.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-10-2002, 07:54 PM   #7
jhow66
jhow66's Avatar
fan
Sorry forgot to tell you how to check fan speed--disconnect wire at fan motor and run a jumber from battery hot post to fan--this is how fast it should run on high.
