11-17-2005, 12:26 AM | #1 |
Six cylinder dual exhaust question
Does anybody have any pictures of a 6 cyl. dual exhaust? I have headers and was wanting to run the pipes out in front of the rear wheels and keep all the pipes in the frame and not hanging down below frame. Both pipes on the same side, unless someone has a good way to run them through the transmission.
1969 C-10,short bed, I6 250, 3x1 offy, HEI, headers, 5 speed, original paint and family owned! |
11-17-2005, 09:33 AM | #2 |
Re: Six cylinder dual exhaust question
i guess no body has pics, are you going to cut openings in your crossmember?
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
11-17-2005, 10:03 AM | #3 |
I am planning on doing a similar setup with my I6.....not sure if I want to put duals on, or just use a y-pipe to collect the two headers, and dump them into a single larger exhaust.
Speaking of which, anyone have any opinions on using a muffler as an equalizer/y-pipe.....I was wondering if I could get away with using a muffler with two pipes to one.....but I think they are traditionally inlet/outlet on one side, and outlet on the other.....is this going to be a problem? Staying on topic though....any pics of how someone routed their exhaust with I6 headers will be helpful! |
11-28-2005, 10:56 PM | #4 |
I am not sure if I will be cutting the crossmember, but I don't see any other way about it. I have some time off after Christmas, so I will have some progress done during that time and will post the results.
11-29-2005, 04:22 AM | #5 |
Questionable
What inline you got, 250 or 292? What headers are you using that don't go below the framerails? I have install pictures from my headers and you can see on page two how low slung they were on my 250:
http://satellitehead.com/gallery/thumbnails.php?album=8 You must have some shorties!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-29-2005, 06:37 AM | #6 |
I have a dual set-up on my stepside. Clifford headers out of a 292 to 1-7/8" tubes, H-pipe [more like a Russian <<N>>] after 465 tranny, thru turbo mufflers [2] and out behind tires. Chrome slant tips. Works fine, been on since mid '80s.
11-29-2005, 08:39 AM | #7 |
that is awesome to see that the headers clear the column shifter bracket......that was my only concern! thanks for the pics shifty!
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
