Old 11-17-2005, 01:26 AM   #1
Blue4x4
Blue4x4's Avatar
any dual shock pic's?
Anyone running dual shocks, please post a few pic's and let me know what brand you are running...thanks.
Blue4x4 is offline   Reply With Quote
Old 11-17-2005, 09:35 AM   #2
jakeslim
Premium Level Member
jakeslim's Avatar
Re: any dual shock pic's?
dual's = rough ride. I had them on my 77 when I first bought it..ouch. No need for them. One shock of good quality is more than enough in my opinion.
Most people run them just for looks, but I'm sure they sacrifice ride quality
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 11-17-2005, 09:59 AM   #3
53burb
53burb's Avatar
I believe some people drill holes in the second shock to relieve the gas pressure to make it useless and not hurt the ride. It would only be for looks after that.
53burb is offline   Reply With Quote
Old 11-17-2005, 10:38 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
You can actually buy shocks that are designed to be used as a pair. If you use a pair that aren't designed to be used as a pair, you definitely get a rough ride.
I don't recall seeing any shots of a first gen with dual shocks that I could dig up for you.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-17-2005, 12:11 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I read on CK5.com once, that someone was using ford f150 shock towers to run dual shocks. I don't know if they uses an aftermarket shock hoop or if it was a stock f150 setup.
Check the forums on CK5.com and Pirate4x4.com.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-17-2005, 10:52 PM   #6
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I don't run dual shocks but my Blazer has the bracket for it.
On the left side of the pic. the inner bracket is the factory piece and the outer one is the dealer installed one.It's welded on.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 11-17-2005, 11:19 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Interesting
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-18-2005, 11:11 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That dual shock set-up shuold be pretty easy to dupilcate. Bobby are those the tranny cooler lines on the outside of the frame rail???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-18-2005, 11:20 PM   #9
bouncytruck
SKINNY TIRES RULE!
The lines are probably fuel lines for his TPI system.
bouncytruck 1972 K5
Old 11-19-2005, 12:14 PM   #10
BobS
BobS's Avatar
Here's a couple of pics of the factory setup used in about 85-87 or so.
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 11-20-2005, 09:02 PM   #11
BobbyK
BobbyK's Avatar
Yup.They are my transmission lines.
When I redid my trans lines I didn't want to mess around trying to get them to fit on the inside rail...so I ran them on the outside.
Made up some stainless covered rubber lines to join the hard lines between body panels(frame to rad. core,frame to trans.)
Old 11-21-2005, 02:11 PM   #12
I made some like this.I modeled them of of ones I bought from Dick Cepek.The idea was to even-out the handling since all the weight is up front,especially on a pickup.This helped prevent bottoming back in theday when high performance 4 wheeling was all Baja style.There weren`t gas shocks yet and heavy-duty was the name of the game.That`s why even on my`91 Suburban GM used duals because of the extra weight of the diesel.Until IFS,you expected and wanted what is known as a rough ride by todays standards.We used to call everything else mushy.
