Old 11-17-2005, 09:05 AM   #1
76bonanza
76bonanza's Avatar
spark plug question
A colder plug will make more power but have a better chance of fouling correct?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 11-17-2005, 06:12 PM   #2
70rs/ss
70rs/ss's Avatar
Re: spark plug question
This is one of those it depends on a lot of factors answers. A hotter spark will burn everything and is sometimes needed. If your plugs are that nice brownish color replace them with the same plug. If you have wet plugs or a little oil a hotter plug may help, but be aware there is something else up. There is also a need for hottor plugs to burn Nitrous, etc, etc.
70rs/ss is offline   Reply With Quote
Old 11-17-2005, 06:47 PM   #3
76bonanza
76bonanza's Avatar
I emailed ngk my motor specs and they recommended I use one step colder than stock in my motor. Just wondering if this will make more power or be more of a hassle?
1968 c10
lowered 3" 4"
Old 11-17-2005, 07:09 PM   #4
crazy longhorn
Fabricate till you "puke"
Last trip into the local speed shop, they knocked me back a number or 2 on the plugs......yes it does make more power, as long as they arent too cold(then they foul ). I havent had any troubles with the colder plugs, but its "experimental". just dont spend the bucks on platinums, till you get the heat range sorted out best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-17-2005, 07:33 PM   #5
bigjimzlll
bigjimzlll's Avatar
actually you run a colder plug for Nitrous..the Nitrous increases the cylinder pressure...kinda like forced induction...effectively inceasing the compression ratio
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 11-17-2005, 08:09 PM   #6
76bonanza
76bonanza's Avatar
anyone use the ngk iriduim pkugs? Just a waste of money?
1968 c10
lowered 3" 4"
