11-17-2005, 08:30 PM | #1 |
Center cap question
I have what I think are truck rallys looking for some way to spice them up a little, more shine little more stand out. Wondering what center caps or hub covers I can use or other ways to make them not so plain jane.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO Last edited by 76bonanza; 08-20-2006 at 01:48 PM. |
11-17-2005, 08:36 PM | #2 |
Watch out for your cornhole !
Re: Center cap question
Some guys use little convex spot mirrors on the center caps. They are adhesive backed and fit the center indention of the cap perfectly. It looks like a tiny baby moon in the middle.
11-17-2005, 08:42 PM | #3 |
fThis is what TX was talking about. I had these on my 70. I like the look even bettter than stock. You can also swap out and use late model centercaps/lugs, which I don't have a picture of.
11-17-2005, 08:45 PM | #4 |
Gone Fishing
You can also change the decal on the center cap to a custom style. I have seen the decals at most of the local swap meets.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
11-17-2005, 08:47 PM | #5 |
where did you get those little mirror things and how did they attach? Not sure if I like or not but neat. Was look more for something to cover the whole center lug part and not use the stock caps at all.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
11-17-2005, 09:08 PM | #6 |
I got mine at Walmart....about a $1 eac. they have self stick tape on the back. Buy 5. If it does happen to fall off, you'll have a spare and it is much cheaper than the decals. BTW I lost one in 13 months, but that was because of my own stupidity....but I had a spare
11-17-2005, 09:23 PM | #7 |
automotive section?
11-17-2005, 09:26 PM | #8 |
You can also take an SOS pad and gently srape all the flat silver paint off the area surrounding the lug holes. That part was chromed as well as the hub part, GM just decided to paint it over.
"You can take the man out of PA, but you can't take PA out of the man" |
11-17-2005, 10:30 PM | #9 |
newer style caps say 99 -02bowtie centers you can buy daul thread lugnuts for the plastic nut caps or you drill and tap three studs out in the back of them theyll bolt in just like the ones you have but from the backside then use chrome lugs they look really good someone posted pics of a set awhile back
11-17-2005, 10:38 PM | #10 | |
Happy to be here
11-17-2005, 10:38 PM | #11 | |
11-17-2005, 11:29 PM | #12 |
Put some black lug nut covers on them . That will do a lot for them wheels. Get them from Dorman. Threaded lug nut on the out side with screw on lug nut covers.
11-17-2005, 11:35 PM | #13 | |
11-18-2005, 02:48 AM | #14 | |
Thanks . |
11-18-2005, 10:17 AM | #15 |
The one I found at walmart has black plastic around the outside and the mirror on the inside is this them?
11-18-2005, 01:40 PM | #16 |
67-72 Addict!
This is who I buy from:http://cgi.ebay.com/ebaymotors/RALLY...QQcmdZViewItem
The quality and price is very good and he does different colors.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-18-2005, 01:58 PM | #17 |
Old Skool Club
www.summitracing.com has a section in their on-line catalog that shows pictures of different center caps. Seems that prices start as low as ~19 bucks and go up. The caps I want to use are about $23.50 each, in stainless steel.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
11-18-2005, 02:36 PM | #18 |
Those wider trim rings(corvette ones I think) will they fit on any rally rim and were can they be had for resonable?
11-18-2005, 04:54 PM | #19 | |
Yes 76bonanza, those are the ones I used.
