11-17-2005, 10:14 PM | #1 |
Howto: Seal ff 14bolt axels
Dumb question but I can't find any old topics on this. I'm switching out an old ho72 rear end on my 68 k20 for a 14bolt ff rear end. I noticed the last person sealed the axels with silicone, is the a common practice ? I would think I could get gaskets or something better than gooping silicone to seal these axels. The guys at the parts store have no clue.
11-17-2005, 10:37 PM | #2 |
Re: Howto: Seal ff 14bolt axels
You talking about the cover? I have seen it done. You can get a gasket for them but I have seen places use silicone.
11-17-2005, 10:55 PM | #3 |
Nope, the axel part out where your bolt it in by the hub
11-18-2005, 11:21 AM | #4 |
The axles actually have a steel gasket. I cannot find the correct # right now but if you call GM and ask for group 5.819 parts they should be able tolocate it.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
11-18-2005, 11:05 PM | #5 |
The steel shim gasket is no longer available at GM. What they have now is a paper gasket. Silicone will work however, just don't get carried away with it.
11-22-2005, 06:31 PM | #6 |
I believe that it is the same as the Eaton Axle flange gasket
Felpro # 55350, $2 or $3 ea these are the steel ones, makes it alot neater than silicone.
Jim SW PA. 69' GMC SWB 4X4 (in progress). 86' GMC LWB 4X4 (daily) 86' Chevy LWB 4X4 (beater) |
